Reports
Design of Stable Feedback Controllers for Second Order Systems with Varying Sampling Rate: LQ and Lie-Algebraic Approaches
Flavia Felicioni 1, 2
1 TRIO - Real time and interoperability
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : Abstract: In this article, we consider the design of a controller family that given a second-order continuous-time linear plant controlled at a varying rate, asymptotically stabilizes the closed loop and provides a good performance. Rate adaptation of control task execution is increasingly used in order to optimize allocation and throughput of shared resources in embedded systems. The LQ technique, tipically used to adapt the controller parameters to rate variation, is compared with a Lie-algebraic method [7] which guarantees the existence of a common Lyapunov function for the varying-time system. The use of a performance index as a function of the rate, derived from the discrete Lyapunov function and related with closed-loop eigenvalues, simplifies the evaluation of the cost associated with each rate.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00344849
Contributor : Flavia Felicioni Connect in order to contact the contributor
Submitted on : Friday, December 5, 2008 - 7:12:52 PM
Last modification on : Friday, February 4, 2022 - 3:21:56 AM
Long-term archiving on: : Monday, June 7, 2010 - 10:26:06 PM
File
RR-6753.pdf
Identifiers
  • HAL Id : inria-00344849, version 1
Collections
Citation
Flavia Felicioni. Design of Stable Feedback Controllers for Second Order Systems with Varying Sampling Rate: LQ and Lie-Algebraic Approaches. [Research Report] RR-6753, INRIA. 2008, pp.21. ⟨inria-00344849⟩
Share
Metrics
Record views
65
Files downloads
66
