Geometry II, Translated from French, 1987. ,
Estimating differential quantities using polynomial fitting of osculating jets, SGP 2003: Proceedings of the 2003 Eurographics, pp.177-187 ,
DOI : 10.1016/j.cagd.2004.09.004
URL : https://hal.archives-ouvertes.fr/hal-00103047
Intrinsic curvatures in analytic-geometric categories, Annales de l???institut Fourier, vol.53, issue.6, pp.1897-1924, 2003. ,
DOI : 10.5802/aif.1995
A Geometric Convection Approach of 3-D Reconstruction, Proceedings of the 1st Symposium on Geometry Processing, pp.218-229, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00071898
Lieutier Normal cone Approximation and Offset Shape Isotopy. INRIA research report Number 6100, 2007. ,
DOI : 10.1016/j.comgeo.2008.12.002
URL : http://doi.org/10.1016/j.comgeo.2008.12.002
A Sampling Theory for Compacts in Euclidean Space, Proceedings of the 22nd ACM Symposium on Computational Geometry, 2006. ,
Stability of Boundary Measures, INRIA's research report N 6219, 2007. ,
The ?????-medial axis???, Graphical Models, vol.67, issue.4, pp.304-331, 2005. ,
DOI : 10.1016/j.gmod.2005.01.002
Weak feature size and persistent homology, Proceedings of the twenty-first annual symposium on Computational geometry , SCG '05, pp.255-262, 2005. ,
DOI : 10.1145/1064092.1064132
OrthoMap: Homeomorphismguaranteeing normal-projection map between surfaces, Proceedings of ACM Symp. on Solid and Physical Modeling, 2005. ,
Critical Points of Distance Functions and Applications to Geometry, Geometric Topology: recent developments, pp.1-38, 1990. ,
Optimization and NonSmooth Analysis, 1983. ,
DOI : 10.1137/1.9781611971309
Quelquesprobì emes liésliés`liésà la discrétisation de surfaces, thèse de l'´ ecole polytechnique, 2004. ,
Restricted delaunay triangulations and normal cycle, Proceedings of the nineteenth conference on Computational geometry , SCG '03, 2003. ,
DOI : 10.1145/777792.777839
Second fundamental measure of geometric sets and local approximation of curvatures, Journal of Differential Geometry, vol.74, issue.3, pp.363-394 ,
DOI : 10.4310/jdg/1175266231
Three-dimensional alpha shapes, ACM Transactions on Graphics, vol.13, issue.1, pp.43-72, 1994. ,
DOI : 10.1145/174462.156635
URL : http://arxiv.org/abs/math/9410208
Surface reconstruction by wrapping finite point sets in space ,
Geometric Measure Theory: an introduction, 2002. ,
Geometric Measure Theory, 1983. ,
DOI : 10.1007/978-3-642-62010-2
Curvature measures, Transactions of the American Mathematical Society, vol.93, issue.3, pp.418-491, 1959. ,
DOI : 10.1090/S0002-9947-1959-0110078-1
Curvature Measures of Subanalytic Sets, American Journal of Mathematics, vol.116, issue.4, pp.819-880 ,
DOI : 10.2307/2375003
Monge-Ampère functions, 1, Indiana Univ Math, J, vol.38, pp.745-771, 1989. ,
The flow complex: A data structure for geometric modeling, Proc. 14th Annual ACM-SIAM Symposium on Discrete Algorithms (SODA), pp.285-294, 2003. ,
DOI : 10.1016/j.comgeo.2007.01.002
Critical point theory for distance functions, Proc. of Symposia in Pure Mathematics, 1993. ,
DOI : 10.1090/pspum/054.3/1216630
Any open bounded subset of has the same homotopy type as its medial axis, Computer-Aided Design, vol.36, issue.11, pp.1029-1046, 2004. ,
DOI : 10.1016/j.cad.2004.01.011
Geometric Measure Theory, 1987. ,
DOI : 10.1016/b978-0-12-506857-4.50005-9
Geometric measure theory and the proof of the double bubble conjecture, Global theory of minimal surfaces, 1-18, Proc., 2, Amer, 2005. ,
A survey of methods for recovering quadrics in triangle meshes, ACM Computing Surveys, vol.34, issue.2, pp.211-262, 2002. ,
DOI : 10.1145/508352.508354
URL : https://hal.archives-ouvertes.fr/inria-00100762
Curvatures and Currents for Unions of Sets with positive reach II, Annals of Global Analysis and Geometry, vol.20, issue.1, pp.1-21, 2001. ,
DOI : 10.1023/A:1010624214933
Normal cycles of Lipschitz manifolds by approximation with parallel sets, Differential Geometry and its Applications, vol.19, issue.1, pp.113-126, 2003. ,
DOI : 10.1016/S0926-2245(03)00020-2
General Normal Cycles and Lipschitz Manifolds of Bounded Curvature, Annals of Global Analysis and Geometry, vol.23, issue.2, pp.135-156, 2005. ,
DOI : 10.1007/s10455-005-5218-x
Calculus on manifolds: A modern approach to classical theorems of advanced calculus, 1965. ,
