On conditional McKean Lagrangian stochastic models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Probability Theory and Related Fields Année : 2011
This paper is motivated by a new class of SDEs--PDEs systems, the so called Lagrangian stochastic models which are commonly used in the simulation of turbulent flows. We study a position--velocity system which is nonlinear in the sense of McKean. As the dynamics of the velocity depends on the conditional expectation w.r.t. its position, the interaction kernel is singular. We prove existence and uniqueness of the solution to the system by solving a nonlinear martingale problem and showing that the corresponding interacting particle system propagates chaos.
RR-lagrangian.pdf (383.89 Ko) Télécharger le fichier
inria-00345524 , version 1 (09-12-2008)
inria-00345524 , version 2 (15-12-2008)
inria-00345524 , version 3 (01-03-2009)
inria-00345524 , version 4 (10-07-2009)
Mireille Bossy, Jean-Francois Jabir, Denis Talay. On conditional McKean Lagrangian stochastic models. Probability Theory and Related Fields, 2011, 151, 1-2, pp.319-351. ⟨10.1007/s00440-010-0301-z⟩. ⟨inria-00345524v4⟩
252 Consultations
494 Téléchargements
