Optimal Grain Size Computation for Pipelined Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1996
In this paper, we present a method for overlapping communications on parallel computers for pipelined algorithms. We first introduce a general theoretical model which leads to a generic computation scheme for the optimal packet size. Then, we use the OPIUM library, which provides an easy-to-use and efficient way to compute, in the general case, this optimal packet size, on the column $LU$ factorization; the implementation and performance measures are made on an Intel Paragon.
Mots clés
Fichier non déposé
inria-00346485 , version 1 (11-12-2008)
  • HAL Id : inria-00346485 , version 1
Frédéric Desprez, Pierre Ramet, Jean Roman. Optimal Grain Size Computation for Pipelined Algorithms. Euro-Par'96, 1996, Lyon, France. pp.165-172. ⟨inria-00346485⟩
87 Consultations
0 Téléchargements
