Partitioning and Blocking Issues for a Parallel Incomplete Factorization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
The purpose of this work is to provide a method which exploits the parallel block-wise algorithmic approach used in the framework of high performance sparse direct solvers in order to develop robust and efficient preconditioners based on a parallel incomplete factorization.
Mots clés
Fichier non déposé
inria-00346624 , version 1 (11-12-2008)
  • HAL Id : inria-00346624 , version 1
Pascal Hénon, Pierre Ramet, Jean Roman. Partitioning and Blocking Issues for a Parallel Incomplete Factorization. PARA'06, 2006, Umea, Sweden. pp.929--937. ⟨inria-00346624⟩
41 Consultations
0 Téléchargements
