Inference of Flow Statistics via Packet Sampling in the Internet - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2008
Yousra Chabchoub
  • Fonction : Auteur
  • PersonId : 838100
Christine Fricker
  • Fonction : Auteur
  • PersonId : 831323
Fabrice Guillemin
We show in this note that by deterministic packet sampling, the tail of the distribution of the original flow size can be obtained by rescaling that of the sampled flow size. To recover information on the flow size distribution lost through packet sampling, we propose some heuristics based on measurements from different backbone IP networks. These heuristic arguments allow us to recover the complete flow size distribution.
Hal.pdf (105.74 Ko) Télécharger le fichier
inria-00347008 , version 1 (13-12-2008)
  • HAL Id : inria-00347008 , version 1
  • ARXIV : 0812.2544
Yousra Chabchoub, Christine Fricker, Fabrice Guillemin, Philippe Robert. Inference of Flow Statistics via Packet Sampling in the Internet. 2008. ⟨inria-00347008⟩
Collections
INRIA INRIA2
47 Consultations
303 Téléchargements
