Robust detection of skew in document images, IEEE Transactions on Image Processing, vol.6, issue.2, pp.344-349, 1997. ,
DOI : 10.1109/83.551708
An automatic algorithm for text skew estimation in document images using recursive morphological transforms, Proc of International Conference on Image Processing, pp.139-143, 1994. ,
A fast algorithm for skew detection of document images using morphology, International Journal on Document Analysis and Recognition, vol.4, issue.2, pp.109-114, 2001. ,
DOI : 10.1007/PL00010902
Temps-fréquence, HERMES, 1993. ,
A method of detecting the orientation of aligned components, Pattern Recognition Letters, vol.4, issue.2, pp.125-132, 1986. ,
DOI : 10.1016/0167-8655(86)90034-6
Skew angle estimation for printed and handwritten documents using the Wigner???Ville distribution, Image and Vision Computing, vol.20, issue.11, pp.813-824, 2002. ,
DOI : 10.1016/S0262-8856(02)00091-4
A Hough based algorithm for extracting text lines in handwritten documents, Proceedings of 3rd International Conference on Document Analysis and Recognition, pp.774-777, 1995. ,
DOI : 10.1109/ICDAR.1995.602017
Extracting lines on handwritten documents by perceptual grouping, in Advances in Handwiting and drawing: a multidisciplinary approach ,
Une méthode de résolution des conflits d'alignements pour la segmentation des documents manuscrits, Traitement du Signal, issue.6, pp.12541-549, 1995. ,
A prototype document image analysis system for technical journals, Computer, vol.25, issue.7, pp.10-22, 1992. ,
DOI : 10.1109/2.144436
A Threshold Selection Method from Gray-Level Histograms, IEEE Transactions on Systems, Man, and Cybernetics, vol.9, issue.1, pp.62-66, 1979. ,
DOI : 10.1109/TSMC.1979.4310076
Repulsive attractive network for baseline extraction on document images, 1997 IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.1-10, 1999. ,
DOI : 10.1109/ICASSP.1997.595468
Skew angle detection of digitized Indian script documents, IEEE Trans. Pattern Anal. Mach. Intell, 1996. ,
Line Separation for Complex Document Images Using Fuzzy Runlength, Proc. Of the Int. Workshop on Document Image Analysis for Libraries, 2004. ,
Arabic hand-written text-line extraction, Proceedings of Sixth International Conference on Document Analysis and Recognition, pp.281-285, 2001. ,
DOI : 10.1109/ICDAR.2001.953799
