On the existence of transmission eigenvalues in an inhomogeneous medium - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Fioralba Cakoni
  • Fonction : Auteur
  • PersonId : 856701
Houssem Haddar
We prove the existence of transmission eigenvalues corresponding to the inverse scattering problem for isotropic and anisotropic media for both scalar Helmholtz equation and Maxwell's equations. Considering a generalized abstract eigenvalue problem, we are able to extend the ideas of Päivärinta and Sylvester to prove the existence of transmission eigenvalues for a larger class of interior transmission problems. Our analysis includes both the case of a medium with positive contrast and of a medium with negative contrast provided that this contrast is large enough.
RR-6779.pdf (268.82 Ko) Télécharger le fichier
inria-00347840 , version 1 (16-12-2008)
  • HAL Id : inria-00347840 , version 1
Fioralba Cakoni, Houssem Haddar. On the existence of transmission eigenvalues in an inhomogeneous medium. [Research Report] RR-6779, INRIA. 2008, pp.24. ⟨inria-00347840⟩
1924 Consultations
524 Téléchargements
