Motion-Based Segmentation of Transparent Layers in Video Sequences, Proc. of International Workshop of Multimedia Content Representation, Classification and Security, 2006. ,
DOI : 10.1007/11848035_40
Determining optical flow, Artificial Intelligence, vol.17, issue.1-3, pp.185-203, 1981. ,
DOI : 10.1016/0004-3702(81)90024-2
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.185.1651
Deriving intrinsic images from image sequences, Proceedings Eighth IEEE International Conference on Computer Vision. ICCV 2001, pp.68-75, 2001. ,
DOI : 10.1109/ICCV.2001.937606
Separating Transparent Layers through Layer Information Exchange, European Conference on Computer Vision (ECCV'04), pp.328-341, 2004. ,
DOI : 10.1007/978-3-540-24673-2_27
Separating transparent layers of repetitive dynamic behaviors, Tenth IEEE International Conference on Computer Vision (ICCV'05) Volume 1, pp.26-32, 2005. ,
DOI : 10.1109/ICCV.2005.216
The Robust Estimation of Multiple Motions: Parametric and Piecewise-Smooth Flow Fields, Computer Vision and Image Understanding, vol.63, issue.1, pp.57-91, 1996. ,
DOI : 10.1006/cviu.1996.0006
Computing occluding and transparent motions, International Journal of Computer Vision, vol.1, issue.1, pp.5-16, 1994. ,
DOI : 10.1007/BF01420982
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.14.9031
Accuracy assessment of layer decomposition using simulated angiographic image sequences, IEEE Transactions on Medical Imaging, vol.20, issue.10, pp.990-998, 2001. ,
DOI : 10.1109/42.959296
Multiple motion analysis: in spatial or in spectral domain?, Computer Vision and Image Understanding, vol.90, issue.2, pp.129-152, 2003. ,
DOI : 10.1016/S1077-3142(03)00011-0
Two-dimensional matched filtering for motion estimation, IEEE Transactions on Image Processing, vol.8, issue.3, pp.438-444, 1999. ,
DOI : 10.1109/83.748900
Motion estimation of transparent objects in the frequency domain, Signal Processing, vol.84, issue.4, pp.709-719, 2004. ,
DOI : 10.1016/j.sigpro.2003.12.008
Principle of superposition: a common computational framework for analysis of multiple motion, Proceedings of the IEEE Workshop on Visual Motion, pp.164-172, 1991. ,
DOI : 10.1109/WVM.1991.212811
A robust multiscale B-spline function decomposition for estimating motion transparency, IEEE Transactions on Image Processing, vol.12, issue.11, pp.1416-1426, 2003. ,
DOI : 10.1109/TIP.2003.818357
Estimation of multiple motions: regularization and performance evaluation, Image and Video Communications and Processing 2003, pp.75-86, 2003. ,
DOI : 10.1117/12.476592
Estimation of multiple motions using block matching and Markov random fields, Visual Communications and Image Processing 2004, pp.274-278, 2004. ,
DOI : 10.1117/12.525378
Optical flow constraint equation extended to transparency, XI European Signal Processing Conference, 2002. ,
Estimation of multiple motions by block matching, 4th ACIS Int. Conf. on Software Engineering, pp.358-362, 2003. ,
Medical Imaging Systems, 2004. ,
Digital image acquisition and processing in medical x-ray imaging, Journal of Electronic Imaging, vol.8, issue.1, pp.7-22, 1999. ,
DOI : 10.1117/1.482680
THE TRANSFORMATION OF POISSON, BINOMIAL AND NEGATIVE-BINOMIAL DATA, Biometrika, vol.35, issue.3-4, pp.246-254, 1948. ,
DOI : 10.1093/biomet/35.3-4.246
Multiple motion estimation and segmentation in transparency, 2000 IEEE International Conference on Acoustics, Speech, and Signal Processing. Proceedings (Cat. No.00CH37100), pp.2087-2090, 2000. ,
DOI : 10.1109/ICASSP.2000.859246
Scene Segmentation from Visual Motion Using Global Optimization, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.9, issue.2, pp.220-228, 1987. ,
DOI : 10.1109/TPAMI.1987.4767896
Motion segmentation and qualitative dynamic scene analysis from an image sequence, International Journal of Computer Vision, vol.49, issue.5, pp.157-182, 1993. ,
DOI : 10.1007/BF01420735
A unified mixture framework for motion segmentation: incorporating spatial coherence and estimating the number of models, Proceedings CVPR IEEE Computer Society Conference on Computer Vision and Pattern Recognition, pp.321-326, 1996. ,
DOI : 10.1109/CVPR.1996.517092
Compact representations of videos through dominant and multiple motion estimation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.18, issue.8, pp.814-830, 1996. ,
DOI : 10.1109/34.531801
Direct incremental model-based image motion segmentation for video analysis, Signal Processing, vol.66, issue.2, pp.143-155, 1998. ,
DOI : 10.1016/S0165-1684(98)00003-6
Geodesic active regions and level set methods for motion estimation and tracking, Computer Vision and Image Understanding, vol.97, issue.3, pp.259-282, 2005. ,
DOI : 10.1016/j.cviu.2003.04.001
Robust Statistics, 1981. ,
Robust Multiresolution Estimation of Parametric Motion Models, Journal of Visual Communication and Image Representation, vol.6, issue.4, pp.348-365, 1995. ,
DOI : 10.1006/jvci.1995.1029
Robust regression using iteratively reweighted least-squares, Communication Statistic-Theory Method A, pp.813-827, 1977. ,
Noise reduction filters for dynamic image sequences: a review, Proceedings of the IEEE, vol.83, issue.9, pp.1272-1292, 1995. ,
DOI : 10.1109/5.406412
Image registration for digital subtraction angiography, International Journal of Computer Vision, vol.31, issue.2/3, pp.227-246, 1999. ,
DOI : 10.1023/A:1008074100927
Guide-wire tracking during endovascular interventions, IEEE Transactions on Medical Imaging, vol.22, issue.8, pp.965-972, 2003. ,
DOI : 10.1109/TMI.2003.815904
Motion-compensated lossless compression schemes for biomedical sequence storage, Picture Coding Symposium, 1993. ,
Graph Cuts and Efficient N-D Image Segmentation, International Journal of Computer Vision, vol.18, issue.9, pp.109-131, 2006. ,
DOI : 10.1007/s11263-006-7934-5
Multiresolution Parametric Estimation of Transparent Motions and Denoising of Fluoroscopic Images, MICCAI'05, pp.352-359, 2005. ,
DOI : 10.1007/11566489_44
