Abstract : A new operator is considered, allowing compact formulae and proofs in the context of the derivation of a transfer matrix with respect to another matrix. The problem of the parametric sensitivity matrix calculation is chosen for illustration. It consists in deriving a Multiple Input Multiple Output transfer function with respect to a parametric matrix and is central in robust control theory. Efficient algorithms may be straightforwardly got from the compact analytic formulae using the operator introduced.
