New interface
Conference papers
Constraint-based Ground contact handling in Humanoid Robotics Simulation
Eduardo Martin Moraud 1, 2 Joshua G. Hale 2 Gordon Cheng 2
1 CORTEX - Neuromimetic intelligence
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : This paper presents a method for resolving contact in dynamic simulations of articulated figures. It is intended for humanoids with polygonal feet and incorporates Coulomb friction exactly. The proposed technique is based on a constraint selection paradigm. Its implementation offers an exact mode which guarantees correct behavior, as well as an efficiency optimized mode which sacrifices accuracy for a tightly bounded computational burden, thus facilitating batch simulations or the use of highly detailed foot models. The method has been applied to the simulation of two humanoid robots, CB and Hoap-2, and validated with respect to human and robot motions recorded in reality and in simulation. The friction parameters of contact have also been established empirically.
Document type :
Conference papers
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/inria-00350114
Contributor : Eduardo Martin Moraud Connect in order to contact the contributor
Submitted on : Monday, January 5, 2009 - 9:26:27 PM
Last modification on : Tuesday, July 5, 2022 - 8:38:22 AM
Long-term archiving on: : Tuesday, June 8, 2010 - 4:59:58 PM
File
Constraint-based_Ground_contac...
Identifiers
  • HAL Id : inria-00350114, version 1
Collections
Citation
Eduardo Martin Moraud, Joshua G. Hale, Gordon Cheng. Constraint-based Ground contact handling in Humanoid Robotics Simulation. 2008 IEEE/RAS International Conference on Robotics and Automation - ICRA 2008 Workshop on Contact Models for Manipulation and Locomotion, May 2008, Pasadena, CA, United States. ⟨inria-00350114⟩
Share
Metrics
Record views
192
Files downloads
377
