Abstract : The aim of a Software Transactional Memory (STM) is to discharge the programmers from the management of synchronization in multiprocess programs that access concurrent objects. To that end, a STM system provides the programmer with the concept of a transaction: each sequential process is decomposed into transactions, where a transaction encapsulates a piece of sequential code accessing concurrent objects. A transaction contains no explicit synchronization statement and appears as if it has been executed atomically. Due to the underlying concurrency management, a transaction commits or aborts. Up to now, few papers focused on the definition of consistency conditions suited to STM systems. One of them has recently proposed the opacity consistency condition. Opacity involves all the transactions (i.e., the committed plus the aborted transactions). It requires that (1) until it aborts (if ever it does) a transaction sees a consistent global state of the concurrent objects, and (2) the execution is linearizable (i.e., it could have been produced by a sequential execution -of the same transactions- that respects the real time order on the non-concurrent transactions). This paper is on consistency conditions for transactional memories. It first presents a framework that allows defining a space of consistency conditions whose extreme endpoints are serializability and opacity. It then extracts from this framework a new consistency condition that we call virtual world consistency. This condition ensures that (1) each transaction (committed or aborted) reads values from a consistent global state, (2) the consistent global states read by committed transactions are mutually consistent, but (3) the consistent global states read by aborted transactions are not required to be mutually consistent. Interestingly enough, this consistency condition can benefit lots of STM applications as, from its local point of view, a transaction cannot differentiate it from opacity. Finally, the paper presents and proves correct a STM algorithm that implements the virtual world consistency condition. Interestingly, this algorithm distinguishes the serialization date of a transaction from its commit date (thereby allowing more transactions to commit).
