New interface
Conference papers
3D navigation based on a visual memory
A. Remazeilles 1 François Chaumette 1 Patrick Gros 2
1 Lagadic - Visual servoing in robotics, computer vision, and augmented reality
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
2 TEXMEX - Multimedia content-based indexing
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : This paper addresses the design of a control law for vision-based robot navigation. The method proposed is based on a topological representation of the environment. Within this context, a learning stage enables a graph to be built in which nodes represent views acquired by the camera, and edges denote the possibility for the robotic system to move from one image to an other. A path finding algorithm then gives the robot a collection of views describing the environment it has go through in order to reach its desired position. This article focuses on the control law used for controlling the robot motion's on-line. The particularity of this control law is that it does not require any reconstruction of the environment, and does not force the robot to converge towards each intermediary position in the path. Landmarks matched between each consecutive views of the path are considered as successive features that the camera has to observe within its eld of view. A visual servoing control law is designed using specific features which ensures that the robot navigates within the visibility path. Simulation results demonstrate the validity of the proposed approach.
Document type :
Conference papers
Complete list of metadata
Cited literature [21 references]  Display  Hide  Download
https://hal.inria.fr/inria-00350323
Contributor : Eric Marchand Connect in order to contact the contributor
Submitted on : Tuesday, January 6, 2009 - 2:21:38 PM
Last modification on : Thursday, January 20, 2022 - 4:20:31 PM
Long-term archiving on: : Tuesday, June 8, 2010 - 6:42:00 PM
File
2006_icra_remazeilles.pdf
Identifiers
  • HAL Id : inria-00350323, version 1
Citation
A. Remazeilles, François Chaumette, Patrick Gros. 3D navigation based on a visual memory. IEEE Int. Conf. on Robotics and Automation, ICRA'2006, 2006, Orlando, Florida, United States. pp.2719-2725. ⟨inria-00350323⟩
Share
Metrics
Record views
226
Files downloads
197
