HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Feature points tracking using photometric model and colorimetric invariants
Abstract : This article proposes several colour points tracking methods which are robust to illumination changes. Firstly, the illumination correction is achieved by computing simultaneously a local photometric model and a motion model during the image sequence. Secondly, some colour invariants are used to compensate in each point for the illumination changes. Then, since most of these attributes are not sufficiently robust to model specular highlights occurrence, we propose a third method which jointly uses a local photometric model and a global correction, by using colour invariants. To finish, the three methods are compared through experimental results, on images sequences where specular highlights and lighting changes appear.
Document type :
Conference papers
Complete list of metadata
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/inria-00350327
Contributor : Eric Marchand Connect in order to contact the contributor
Submitted on : Tuesday, January 6, 2009 - 2:21:46 PM
Last modification on : Wednesday, October 20, 2021 - 3:22:08 AM
Long-term archiving on: : Thursday, October 11, 2012 - 3:22:41 PM
File
2006_cgiv_gouiffes.pdf
Identifiers
  • HAL Id : inria-00350327, version 1
Citation
M. Gouiffès, Christophe Collewet, Christine Fernandez-Maloigne, A. Trémeau. Feature points tracking using photometric model and colorimetric invariants. 3rd European Conf. on Colour in Graphics, Imaging, and Vision, CGIV'2006, 2006, Leeds, UK, France. pp.18-23. ⟨inria-00350327⟩
Share
Metrics
Record views
258
Files downloads
59
