A Fully Equivalent Global Pressure Formulation for Three-Phase Compressible Flow - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
We introduce a new global pressure formulation for immiscible three-phase compressible flows in porous media which is fully equivalent to the original equations, unlike the one introduced in \cite{CJ86}. In this formulation, the total volumetric flow of the three fluids and the global pressure follow a classical Darcy law, which simplifies the resolution of the pressure equation. However, this global pressure formulation exists only for Total Differential (TD) three-phase data, which depend only on two functions of saturations and global pressure: the global capillary pressure and the global mobility. Hence we introduce a class of interpolation which constructs such TD-three-phase data from any set of three two-phase data (for each pair of fluids) which satisfy a TD-compatibility condition.
RR-6788.pdf (240.81 Ko) Télécharger le fichier
inria-00350459 , version 1 (06-01-2009)
  • HAL Id : inria-00350459 , version 1
  • ARXIV : 0901.1462
Guy Chavent. A Fully Equivalent Global Pressure Formulation for Three-Phase Compressible Flow. [Research Report] RR-6788, INRIA. 2008, pp.16. ⟨inria-00350459⟩
212 Consultations
299 Téléchargements
