Visual path following using only monocular vision
The video shows the French intelligent transportation vehicle CyCab performing visual path following using only monocular vision. All phases of the process are shown with a spoken commentary. In the teaching phase, the user drives the robot manually while images from the camera are stored. Key images with corresponding images features are stored as a map together with 2D and 3D local information. In the navigation phase, CyCab follows the learned path by tracking the images features projected from the map and with a simple visual servoing control law.
Robotique [cs.RO]
