Abstract : Toyama proved that the union of two confluent term-rewriting systems that share absolutely no function symbols or constants is likewise confluent, a property called modularity. The proof of this beautiful modularity result, technically based on slicing terms into an homogeneous cap and a so called alien, possibly heterogeneous substitution, was later substantially simplified by Klop, Middledorp, Toyama and de Vrijer. In this paper we present a further simplification of the proof of Toyama's result for confluence, which shows that the crux of the problem lies in two different properties: a cleaning lemma, whose goal is to anticipate the application of collapsing reductions; a modularity property of ordered completion, that allows to pairwise match the caps and alien substitutions of two equivalent terms. We then show that Toyama's modularity result scales up to rewriting modulo equations under natural assumptions met by all relations introduced in the litterature.
