Asservissement visuel basé sur des informations photométriques, 16e congrès francophone AFRIF-AFIA Reconnaissance des Formes et Intelligence Artificielle, RFIA'08, 2008. ,
Determining the camera and light source location for a visual task, Proceedings, 1989 International Conference on Robotics and Automation, pp.509-514, 1989. ,
DOI : 10.1109/ROBOT.1989.100037
Automatic sensor placement from vision task requirements, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.10, issue.3, pp.407-416, 1988. ,
DOI : 10.1109/34.3905
Edge-based placement of camera and light source for object recognition and location, [1993] Proceedings IEEE International Conference on Robotics and Automation, pp.586-592, 1993. ,
DOI : 10.1109/ROBOT.1993.291895
Illumination control as a means of enhancing image features in active vision systems, IEEE Transactions on Image Processing, vol.4, issue.11, pp.1520-1530, 1995. ,
DOI : 10.1109/83.469933
A new approach to visual servoing in robotics, IEEE Transactions on Robotics and Automation, vol.8, issue.3, pp.313-326, 1992. ,
DOI : 10.1109/70.143350
Feature point tracking : robustness to specular highlights and lighting variations, European Conf. on Computer Vision, pp.92-93, 2006. ,
Efficient region tracking with parametric models of geometry and illumination, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.20, issue.10, pp.1025-1039, 1998. ,
DOI : 10.1109/34.722606
Light source position and reflectance estimation from a single view without the distant illumination assumption, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.27, issue.4, pp.493-505, 2005. ,
DOI : 10.1109/TPAMI.2005.82
Robot Vision, 1987. ,
Determining optical flow, Artificial Intelligence, vol.17, issue.1-3, pp.185-203, 1981. ,
DOI : 10.1016/0004-3702(81)90024-2
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.185.1651
A tutorial on visual servo control, IEEE Transactions on Robotics and Automation, vol.12, issue.5, pp.651-670, 1996. ,
DOI : 10.1109/70.538972
Real-Time feature tracking and outlier rejection with changes in illumination, ICCV, pp.684-689, 2001. ,
Automatic supervisory control of the configuration and behavior of multibody mechanisms, IEEE Trans. on Systems, Man and Cybernetics, vol.7, issue.12, pp.868-871, 1977. ,
Dynamic sensor planning in visual servoing, Proceedings. 1998 IEEE International Conference on Robotics and Automation (Cat. No.98CH36146), pp.1988-1993, 1998. ,
DOI : 10.1109/ROBOT.1998.680607
URL : https://hal.archives-ouvertes.fr/inria-00352560
ViSP for visual servoing: a generic software platform with a wide class of robot control skills, IEEE Robotics & Automation Magazine, vol.12, issue.4, pp.40-52, 2005. ,
DOI : 10.1109/MRA.2005.1577023
URL : https://hal.archives-ouvertes.fr/inria-00351899
Illumination planning for object recognition using parametric eigenspaces, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.16, issue.12, pp.1219-1227, 1994. ,
DOI : 10.1109/34.387485
Integrating sensor placement and visual tracking strategies, IEEE Int. Conf. Robotics and Automation, pp.1351-1356, 1994. ,
DOI : 10.1007/bfb0027593
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.1029.945
Illumination for computer generated pictures, Communications of the ACM, vol.18, issue.6, pp.311-317, 1975. ,
DOI : 10.1145/360825.360839
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.330.4718
Automatic planning of light source and camera placement for an active photometric stereo system, Proceedings. 1991 IEEE International Conference on Robotics and Automation, pp.1080-1087, 1991. ,
DOI : 10.1109/ROBOT.1991.131737
Robot Control : the Task Function Approach, 1991. ,
A Framework for the Construction of Reflectance Maps for Machine Vision, Computer Vision and Image Understanding, vol.57, issue.3, pp.265-282, 1993. ,
DOI : 10.1006/cviu.1993.1019
Theory for Off-Specular Reflection From Roughened Surfaces*, Journal of the Optical Society of America, vol.57, issue.9, pp.1105-1114, 1967. ,
DOI : 10.1364/JOSA.57.001105
Optimal Sensor and Light Source Positioning for Machine Vision, Computer Vision and Image Understanding, vol.61, issue.1, pp.122-137, 1995. ,
DOI : 10.1006/cviu.1995.1009
Shape-from-shading: a survey, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.21, issue.8, pp.690-706, 1999. ,
DOI : 10.1109/34.784284
