Abstract : In this paper, we analyze and compare four image-based visual servoing control laws. Three of them are classical while a new one is proposed. This new control law is based on a behavior controller to adjust the movement of the camera. It can also be used to switch between the classical methods. An analytical study of all control schemes when translational motion along and rotational motion around the optical axis is also presented. Finally, simulation and experimental results show that the new control law with a behavior controller has a wider range of success than the other control schemes and can be used to avoid local minima and singularities.
https://hal.inria.fr/inria-00351871 Contributor : Eric MarchandConnect in order to contact the contributor Submitted on : Monday, January 12, 2009 - 10:10:39 AM Last modification on : Thursday, January 20, 2022 - 4:19:47 PM Long-term archiving on: : Tuesday, June 8, 2010 - 5:25:20 PM
M. Marey, François Chaumette. A behavior-based visual servoing control law. Mediterranean Conf. on Intelligent Systems and Automation, CISA'08, 2008, Annaba, Algeria, France. ⟨inria-00351871⟩
