HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
Complex articulated object tracking.
Andrew Comport 1 E. Marchand 1 François Chaumette 1
1 Lagadic - Visual servoing in robotics, computer vision, and augmented reality
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : In this paper new results are presented for tracking complex multi-body objects. The theoretical framework is based on robotics techniques and uses an a-priori model of the object including a general mechanical link description. A new kinematic-set formulation takes into account that articulated degrees of freedom are directly observable from the camera and therefore their estimation does not need to pass via a kinematicchain back to the root. By doing this the tracking techniques are efficient and precise leading to real-time performance and accurate measurements. The system is locally based upon an accurate modeling of a distance criteria. A general method is given for defining any type of mechanical link and experimental results show prismatic, rotational and helical type links. A statistical M-estimation technique is applied to improve robustness. A monocular camera system was used as a real-time sensor to verify the theory.
Document type :
Journal articles
Complete list of metadata
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/inria-00351887
Contributor : Eric Marchand Connect in order to contact the contributor
Submitted on : Monday, January 12, 2009 - 10:23:15 AM
Last modification on : Thursday, January 20, 2022 - 4:20:30 PM
Long-term archiving on: : Tuesday, June 8, 2010 - 7:26:18 PM
File
2005_elcvia_comport.pdf
Identifiers
  • HAL Id : inria-00351887, version 1
Citation
Andrew Comport, E. Marchand, François Chaumette. Complex articulated object tracking.. Electronic Letters on Computer Vision and Image Analysis, Computer Vision Center Press, 2005, 5 (3), pp.20-30. ⟨inria-00351887⟩
Share
Metrics
Record views
194
Files downloads
137
