HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Improvements in robust 2D visual servoing
E. Marchand 1 Andrew Comport 1 François Chaumette 1
1 Lagadic - Visual servoing in robotics, computer vision, and augmented reality
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : A fundamental step towards broadening the use of real world image-based visual servoing is to deal with the important issues of reliability and robustness. In order to address this issue, a closed loop control law is proposed that simultaneously accomplishes a visual servoing task and is robust to a general class of image processing errors. This is achieved with the application of widely accepted statistical techniques of robust M-estimation. Furthermore improvement have been added in the weight computation process: memory, initialization. Indeed, when the error between current visual features and desired ones are large, which occurs when large robot displacement are required, M-estimator may not detect outliers. To address this point, the method we propose to initialize the confidence in each feature is based on the LMedS estimators. Experimental results are presented which demonstrate visual servoing tasks which resist severe outlier contamination.
Document type :
Conference papers
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/inria-00352029
Contributor : Eric Marchand Connect in order to contact the contributor
Submitted on : Monday, January 12, 2009 - 1:53:40 PM
Last modification on : Thursday, January 20, 2022 - 4:20:26 PM
Long-term archiving on: : Tuesday, June 8, 2010 - 7:32:05 PM
File
2004_icra_marchand.pdf
Identifiers
  • HAL Id : inria-00352029, version 1
Citation
E. Marchand, Andrew Comport, François Chaumette. Improvements in robust 2D visual servoing. IEEE Int. Conf. on Robotics and Automation, ICRA'04, 2004, New Orleans, Louisiana, France. pp.745-750. ⟨inria-00352029⟩
Share
Metrics
Record views
301
Files downloads
184
