New interface
Conference papers
Central catadioptric visual servoing from 3D straight lines
Youcef Mezouar 1 Hicham Hadj-Abdelkader 1 P. Martinet 1 François Chaumette 2
2 Lagadic - Visual servoing in robotics, computer vision, and augmented reality
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : In this paper we consider the problem of controlling a robotic system using the projection of 3D lines in the image plane of central catadioptric systems. Most of the effort in visual servoing are devoted to points, only few works have investigated the use of lines in visual servoing with traditional cameras and none has explored the case of omnidirectional cameras. First a generic central catadioptric interaction matrix for the projection of 3D straight lines is derived from the projection model of an entire class of camera. Then an image-based control law is designed and validated through simulation results.
Document type :
Conference papers
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/inria-00352033
Contributor : Eric Marchand Connect in order to contact the contributor
Submitted on : Monday, January 12, 2009 - 1:57:02 PM
Last modification on : Friday, April 15, 2022 - 11:08:03 AM
Long-term archiving on: : Tuesday, June 8, 2010 - 7:32:58 PM
File
2004_iros_mezouar.pdf
Identifiers
  • HAL Id : inria-00352033, version 1
Citation
Youcef Mezouar, Hicham Hadj-Abdelkader, P. Martinet, François Chaumette. Central catadioptric visual servoing from 3D straight lines. IEEE/RSJ Int. Conf. on Intelligent Robots and Systems, IROS'04, 2004, Sendai, Japan. pp.343-349. ⟨inria-00352033⟩
Share
Metrics
Record views
218
Files downloads
185
