Chaumette : Visual servoing based on dynamic vision, ICRA'03, 2003. ,
Visual servo control for the hovering of an outdoor robotic airship. ICRA'02, pp.2287-2793, 2002. ,
Danès : Handling visual servoing schemes through rational systems and LMIs, 40th IEEE Conf. on Decision and Control, CDC'01, pp.3601-3606, 2001. ,
DOI : 10.1109/.2001.980419
Malis : Vision-based control with respect to planar and non-planar objects using a zooming camera IEEE Int, Conf. on Advanced Robotics, ICAR'03, 2003. ,
Improving image-based visual servoing with 3D features, Int. Journal of Robotics Research, 2003. ,
DOI : 10.1177/027836490302210003
URL : https://hal.archives-ouvertes.fr/hal-00095015
Asservissement visuel Commande des robots manipulateurs, pp.103-150, 2002. ,
Chaumette : A real-time tracker for markerless augmented reality, IS- MAR'03, 2003. ,
Chaumette : A visual servoing control law that is robust to image outliers, IROS'03, 2003. ,
A gain scheduled control for visual servoing for a flexible arm, IFAC Symp. on Robust Control Design, p.3, 2003. ,
Visual servoing of a 6-DOF manipulator for unknown 3D profile following, Proceedings 1999 IEEE International Conference on Robotics and Automation (Cat. No.99CH36288C), pp.511-520, 2002. ,
DOI : 10.1109/ROBOT.1999.774091
Marescaux : Model predictive control for tracking of repetitive organ motions during teleoperated laparoscopic interventions, European Conf. on Control, ECC'03, 2003. ,
Visual servoing of an under-actuated dynamic rigid-body system: an image-based approach, IEEE Transactions on Robotics and Automation, vol.18, issue.2, pp.187-198, 2002. ,
DOI : 10.1109/TRA.2002.999647
Autonomous 3-d positioning of surgical instruments in robotized laparoscopic surgery using visual servoing, IEEE Transactions on Robotics and Automation, vol.19, issue.5, 2003. ,
DOI : 10.1109/TRA.2003.817086
Theoretical improvements in the stability analysis of a new class of model-free visual servoing methods, IEEE Transactions on Robotics and Automation, vol.18, issue.2, pp.176-186, 2002. ,
DOI : 10.1109/TRA.2002.999646
URL : https://hal.archives-ouvertes.fr/inria-00352094
Rives : Intrinsics-free visual servoing with respect to straight lines, IROS'02, 2002. ,
DOI : 10.1109/irds.2002.1041419
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.59.594
Rives : Robustness of image-based visual servoing with respect to depth distribution errors, ICRA'03, 2003. ,
212D Visual Servoing with Respect to Planar Contours having Complex and Unknown Shapes, The International Journal of Robotics Research, vol.12, issue.5, 2003. ,
DOI : 10.1177/027836490302210004
Visual servoing invariant to changes in camera intrinsic parameters, Proceedings Eighth IEEE International Conference on Computer Vision. ICCV 2001, 2003. ,
DOI : 10.1109/ICCV.2001.937592
URL : https://hal.archives-ouvertes.fr/inria-00072278
Courty : Controlling a camera in a virtual environment, The Visual Computer Journal, pp.1-19, 2002. ,
Path planning for robust image-based control, IEEE Transactions on Robotics and Automation, vol.18, issue.4, pp.534-549, 2002. ,
DOI : 10.1109/TRA.2002.802218
URL : https://hal.archives-ouvertes.fr/inria-00352101
Chaumette : Optimal camera trajectory with image-based control, Int, Journal of Robotics Research, Special Issue on Visual Servoing, 2003. ,
DOI : 10.1177/027836490302210001
Robust and uncalibrated visual servoing without Jacobian using a simplex method, IEEE/RSJ International Conference on Intelligent Robots and System, 2002. ,
DOI : 10.1109/IRDS.2002.1041407
Dynamical sequence of multi-sensor based tasks for mobile robots navigation, 7 th Int, SYROCO'03, 2003. ,
Application of moment invariants to visual servoing, ICRA'03, 2003. ,
Gallice : Position-based visual servoing: keeping the object in the field of vision, 2002. ,
ContributionsàContributions`Contributionsà l'asservissement visuel robuste Thèse de l, 2003. ,
Plestan : Sensor based robot control in the presence of uncertainties: bounding the task function tracking errors. ICRA'02, 2002. ,
