Abstract : In this paper, we determine the analytical form of the interaction matrix related to any moments that can be computed from binary or segmented images. We then apply this theoretical result to image-based visual servoing by selecting six combinations of mo- ments able to control the six dof of the system. The experimental results we present show that a correct behavior of the system is obtained if we consider ei- ther a simple symetrical object, either a planar object with complex and unknown shape.
https://hal.inria.fr/inria-00352087 Contributor : Eric MarchandConnect in order to contact the contributor Submitted on : Monday, January 12, 2009 - 2:23:28 PM Last modification on : Friday, February 4, 2022 - 3:16:12 AM Long-term archiving on: : Tuesday, June 8, 2010 - 5:43:25 PM
François Chaumette. A first step toward visual servoing using image moments. IEEE/RSJ Int Conf on Intelligent Robots and Systems, IROS'02, 2002, Lausanne, Switzerland, Switzerland. pp.378-383. ⟨inria-00352087⟩
