HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
A decoupled image space approach to visual servo control of a robotic manipulator.
Abstract : An image-based visual servo control is presented for a robotic manipulator. The proposed control design ad- dresses visual servo of 'eye-in-hand' type systems. Us- ing a novel representation of the visual error based on a spherical representation of target centroid information along with a measure of the rotation between the camera and the target, the control of the position and orientation is decoupled. A non-linear gain introduced into the ori- entation feedback kinematics prevents the target image from leaving the visual field. Semi-global convergence of the closed loop system is proved.
Document type :
Conference papers
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/inria-00352092
Contributor : Eric Marchand Connect in order to contact the contributor
Submitted on : Monday, January 12, 2009 - 2:24:22 PM
Last modification on : Friday, February 4, 2022 - 3:19:57 AM
Long-term archiving on: : Tuesday, June 8, 2010 - 7:37:18 PM
File
2002_icra_mahony.pdf
Identifiers
  • HAL Id : inria-00352092, version 1
Citation
R. Mahony, Tarek Hamel, François Chaumette. A decoupled image space approach to visual servo control of a robotic manipulator.. IEEE Int. Conf. on Robotics and Automation, ICRA'02, 2002, Washington DC, United States. pp.3781-3786. ⟨inria-00352092⟩
Share
Metrics
Record views
249
Files downloads
171
