Virtual visual servoing: A framework for real-time augmented reality - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
This paper presents a framework to achieve real-time augmented reality applications. We propose a framework based on the visual servoing approach well known in robotics. We consider pose or viewpoint computation as a similar problem to visual servoing. It allows one to take advantage of all the research that has been carried out in this domain in the past. The proposed method features simplicity, accuracy, efficiency, and scalability wrt. to the camera model as well as wrt. the features extracted from the image. We illustrate the efficiency of our approach on augmented reality applications with various real image sequences.
2002_eurographics_marchand.pdf (938.32 Ko) Télécharger le fichier
inria-00352096 , version 1 (12-01-2009)
  • HAL Id : inria-00352096 , version 1
E. Marchand, François Chaumette. Virtual visual servoing: A framework for real-time augmented reality. EUROGRAPHICS 2002 Conference Proceeding, 2002, Saarebrün, Germany, Germany. pp.289-298. ⟨inria-00352096⟩
326 Consultations
1590 Téléchargements
