A redundancy-based iterative approach for avoiding joint limits: Application to visual servoing
We propose in this paper new redundancy-based solutions to avoid robot joint limits of a manipulator. We use a control scheme based on the task function approach. We first recall the classical gradient projection approach and we then present a far more efficient method that relies on the iterative computation of motion that does not affect the task achievement and ensures the avoidance problem. We apply this new method in a visual servoing application. We demonstrate the validity of the approach on various real experiments as Well as on the control of a virtual humanoid.
Robotique [cs.RO]
