Vision-based control using probabilistic geometry for objects reconstruction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
We first present a suitable object knowledge representation based on a mixture of stochastic and set membership models and consider an approximation resulting in ellipsoidal calculus by means of a normal assumption for stochastic laws and ellipsoidal over or inner bounding for uniform laws. Then we, build an efficient estimation process integrating visual data online and perform online and optimal exploratory motions for the camera. The control schemes are based on the maximization of the a posteriori predicted information
Mots clés
2001_cdc_flandin.pdf (323.02 Ko) Télécharger le fichier
inria-00352128 , version 1 (12-01-2009)
  • HAL Id : inria-00352128 , version 1
Grégory Flandin, François Chaumette. Vision-based control using probabilistic geometry for objects reconstruction. IEEE Int. Conf. on Decision and Control, CDC'01, 2001, Orlando, Florida, United States. pp.4152-4157. ⟨inria-00352128⟩
258 Consultations
105 Téléchargements
