On the upstream mobility scheme for two-phase flow in porous media - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computational Geosciences Année : 2010
When neglecting capillarity, two-phase incompressible flow in porous media is modelled as a scalar nonlinear hyperbolic conservation law. A change in the rock type results in a change of the flux function. Discretizing in one-dimensional with a finite volume method, we investigate two numerical fluxes, an extension of the Godunov flux and the upstream mobility flux, the latter being widely used in hydrogeology and petroleum engineering. Then, in the case of a changing rock type, one can give examples when the upstream mobility flux does not give the right answer.
RR-6789.pdf (425.04 Ko) Télécharger le fichier
inria-00353627 , version 1 (15-01-2009)
Siddhartha Mishra, Jérôme Jaffré. On the upstream mobility scheme for two-phase flow in porous media. Computational Geosciences, 2010, 14, pp.105-124. ⟨10.1007/s10596-009-9135-0⟩. ⟨inria-00353627⟩
161 Consultations
296 Téléchargements
