Abstract : Developing and optimizing a virtual machine (VM) is a tedious task that requires many years of development. Although VMs share some common principles, such as a Just In Time Compiler or a Garbage Collector, this opportunity for sharing hash not been yet exploited in implementing VMs. This paper describes and evaluates VMKit, a first attempt to build a common substrate that eases the development of high-level VMs. VMKit has been successfully used to build three VMs: a Java Virtual Machine, a Common Language Runtime and a lisp-like language with type inference uvml. Our precise contribution is an extensive study of the lessons learnt in implementing such common infrastructure from a performance and an ease of development standpoint. Our performance study shows that VMKit does not degrade performance on CPU-intensive applications, but still requires engineering efforts to compete with other VMs on memory intensive applications. Our high level VMs are only 20,000 lines of code, it took one of the author a month to develop a Common Language Runtime and implementing new ideas in the VMs was remarkably easy.
