On normals and projection operators for surfaces defined by point sets, Proceedings of the Eurographics Symposium on Point-Based Graphics, pp.149-156, 2004. ,
Anisotropic point set surfaces, Afrigraph '06: Proceedings of the 4th international conference on Computer graphics, pp.7-13, 2006. ,
Point-sampled cell complexes, ACM Transactions on Graphics Proceedings ), vol.25, issue.3, pp.671-680, 2006. ,
Interpolatory point set surfaces -convexity and hermite data, ACM Transactions on Graphics, 2007. ,
Computing and rendering point set surfaces, IEEE Transactions on Computer Graphics and Visualization, vol.9, issue.1, pp.3-15, 2003. ,
Defining point-set surfaces, ACM Transactions on Graphics Proceedings), vol.23, issue.3, pp.264-270, 2004. ,
The domain of a point set surface, Proceedings of the Eurographics Symposium on Point-Based Graphics, pp.139-147, 2004. ,
Robust smoothing of noisy point clouds, In SIAM Geometric Design and Computing, p.13, 2003. ,
Robust locally weighted regression and smoothing scatterplots, Journal of the American Statistical Association, vol.74, pp.859-836, 1979. ,
Robust smooth feature extraction from point clouds, SMI '07: Proceedings of the IEEE International Conference on Shape Modeling and Applications, pp.123-136, 2007. ,
Robust moving least-squares fitting with sharp features, ACM Trans. Graph, vol.24, issue.3, pp.544-552, 2005. ,
Algebraic point set surfaces, ACM Transactions on Graphics Proceedings ), vol.26, issue.23, pp.1-23, 2007. ,
Dynamic sampling and rendering of algebraic point set surfaces, Computer Graphics Forum (Proceedings of Eurographics, vol.27, issue.3, 2008. ,
Robust Statistics Noniterative , feature-preserving mesh smoothing, SIGGRAPH '03: ACM SIGGRAPH 2003 Papers, pp.943-949, 2003. ,
Poisson surface reconstruction, Proceedings of the Eurographics Symposium on Geometry Processing, pp.43-52, 2006. ,
Provably good moving least squares, ACM-SIAM Symposium on Discrete Algorithms, pp.1008-1018, 2005. ,
Datadependent MLS for faithful surface approximation, Symposium on Geometry Processing, pp.59-67, 2007. ,
Mesh-independent surface interpolation Geometric Modeling for Scientific Visualization, pp.37-49, 2003. ,
A survey of robust statistics, Statistical Methods and Applications, vol.15, issue.3, pp.271-293, 2007. ,
On estimating regression. Theory of Probability and its Applications 9, pp.141-142, 1964. ,
Shape modeling with point-sampled geometry, ACM Transactions on Graphics Proceedings), vol.22, issue.3, pp.641-650, 2003. ,
A two-dimensional interpolation function for irregularly-spaced data, ACM national conference, pp.517-524, 1968. ,
Interpolating and approximating implicit surfaces from polygon soup, ACM Transactions on Graphics, pp.896-904, 2004. ,
Kernel regression for image processing and reconstruction, IEEE Transactions on Image Processing, vol.16, issue.2, pp.349-366, 2007. ,
Optimal bandwidth selection for mls surfaces. Shape Modeling and Applications, SMI 2008. IEEE International Conference on, pp.111-120, 2008. ,
