New interface
Journal articles
Dynamic Surfel Set Refinement for High Quality Rendering
Abstract : Splatting-based rendering techniques are currently the best choice for efficient high quality rendering of point-based geometries. However, such techniques are not suitable for large magnification, especially when the object is under-sampled. This work improves the rendering quality of pure splatting techniques using fast dynamic up-sampling algorithms for point-based geometry. Our algorithms are inspired by interpolatory subdivision surfaces where the geometry is refined iteratively. At each step the refined geometry is that from the previous step enriched by a new set of points. The point insertion procedure uses three operators: a local neighborhood selection operator, a refinement operator (adding new points) and a smoothing operator. Even though our insertion procedure makes the analysis of the limit surface complicated and it does not guarantee its G^1 continuity, it remains very efficient for high quality real-time point rendering. Indeed, while providing an increased rendering quality, especially for large magnification, our algorithm needs no other preprocessing nor any additional information beyond that used by any splatting technique.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00355041
Contributor : Gaël Guennebaud Connect in order to contact the contributor
Submitted on : Wednesday, January 21, 2009 - 5:17:40 PM
Last modification on : Monday, July 4, 2022 - 8:48:27 AM
Identifiers
  • HAL Id : inria-00355041, version 1
Citation
Gael Guennebaud, Loic Barthe, Mathias Paulin. Dynamic Surfel Set Refinement for High Quality Rendering. Computers and Graphics, 2004, 28 (6), pp.827-838. ⟨inria-00355041⟩
Share
Metrics
Record views
59
