Optimizing Compilers for Modern Architectures, 2002. ,
Data dependence in ordinary programs Master's thesis, 1976. ,
Maximal static expansion, Proceedings of the 25th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '98, pp.98-106, 1998. ,
DOI : 10.1145/268946.268955
URL : https://hal.archives-ouvertes.fr/hal-01257319
Code generation in the polyhedral model is easier than you think, Proceedings. 13th International Conference on Parallel Architecture and Compilation Techniques, 2004. PACT 2004., pp.7-16, 2004. ,
DOI : 10.1109/PACT.2004.1342537
URL : https://hal.archives-ouvertes.fr/hal-00017260
A practical automatic polyhedral parallelizer and locality optimizer, PLDI'08: Proceedings of the 2008 ACM SIGPLAN conference on Programming language design and implementation, pp.101-113, 2008. ,
Loop parallelization algorithms: From parallelism extraction to code generation, Parallel Computing, vol.24, issue.3-4, 1998. ,
DOI : 10.1016/S0167-8191(98)00020-9
URL : https://hal.archives-ouvertes.fr/hal-00856896
Space-time transformation of while-loops using speculative execution, Proceedings of IEEE Scalable High Performance Computing Conference, 1994. ,
DOI : 10.1109/SHPCC.1994.296675
Automatic parallelization ofwhile-loops using speculative execution, International Journal of Parallel Programming, vol.634, issue.1, pp.191-219, 1995. ,
DOI : 10.1007/BF02577789
Fuzzy array dataflow analysis, PPOPP'95 Proceedings of the fifth ACM SIGPLAN symposium on Principles and practice of parallel programming, pp.92-101, 1995. ,
Exact versus approximate array region analyses, lncs 1239, LCPC'96 9th Annual Workshop on Programming Languages and Compilers for Parallel Computing, pp.86-100, 1996. ,
Dataflow analysis of array and scalar references, International Journal of Parallel Programming, vol.24, issue.4, pp.23-53, 1991. ,
DOI : 10.1007/BF01407931
Some efficient solutions to the affine scheduling problem. I. One-dimensional time, International Journal of Parallel Programming, vol.40, issue.6, pp.313-348, 1992. ,
DOI : 10.1007/BF01407835
Some efficient solutions to the affine scheduling problem. Part II. Multidimensional time, International Journal of Parallel Programming, vol.2, issue.4, pp.389-420, 1992. ,
DOI : 10.1007/BF01379404
Array recovery and high-level transformations for DSP applications, CPC'10 Intl. Workshop on Compilers for Parallel Computers, pp.29-38, 2003. ,
DOI : 10.1145/643470.643472
A scheme for detecting the termination of a parallel loop nest, Proc. GI/ITG FG PARS'98, 1998. ,
Termination detection in parallel loop nests with while loops, Parallel Computing, vol.25, issue.12, pp.1489-1510, 1999. ,
DOI : 10.1016/S0167-8191(99)00063-0
Generation of synchronous code for automatic parallelization of while loops, EURO-PAR '95, pp.315-326, 1995. ,
DOI : 10.1007/BFb0020474
On scanning space-time mapped while loops, CONPAR 94 -VAPP VI: Proceedings of the Third Joint International Conference on Vector and Parallel Processing, pp.677-688, 1994. ,
DOI : 10.1007/3-540-58430-7_59
The Organization of Computations for Uniform Recurrence Equations, Journal of the ACM, vol.14, issue.3, pp.563-590, 1967. ,
DOI : 10.1145/321406.321418
Array SSA form and its use in parallelization, Proceedings of the 25th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '98, pp.107-120, 1998. ,
DOI : 10.1145/268946.268956
The i test: A new test for subscript data dependence, ICPP'90 Intl. Conf. on Parallel Processing, pp.204-211, 1990. ,
Improving Parallelism and Data Locality with Affine Partitioning, 2001. ,
Iterative optimization in the polyhedral model: Part II, multidimensional time, ACM SIGPLAN Conference on Programming Language Design and Implementation (PLDI'08), pp.90-100, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-01257273
An exact method for analysis of value-based array data dependences, LCPC'93 Sixth Annual Workshop on Programming Languages and Compilers for Parallel Computing, pp.546-566, 1993. ,
DOI : 10.1007/3-540-57659-2_31
Generation of efficient nested loops from polyhedra, International Journal of Parallel Programming, vol.28, issue.5, pp.469-498, 2000. ,
DOI : 10.1023/A:1007554627716
The lrpd test: Speculative run-time parallelization of loops with privatization and reduction parallelization, PLDI'95 Proceedings of the ACM SIGPLAN'95 Conference on Programming Language Design and Implementation, pp.218-232, 1995. ,
Hybrid analysis, Proceedings of the 16th international conference on Supercomputing , ICS '02, p.31, 2003. ,
DOI : 10.1145/514191.514229
A LIBRARY FOR DOING POLYHEDRAL OPERATIONS, Parallel Algorithms and Applications, vol.15, issue.3-4, 1993. ,
DOI : 10.1007/BF02574699
URL : https://hal.archives-ouvertes.fr/inria-00074515
