Numerical approximation of Backward Stochastic Differential Equations with Jumps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
In this paper we propose a numerical method to approximate the solution of a Backward Stochastic Differential Equations with Jumps (BSDEJ). This method is based on the construction of a discrete BSDEJ driven by a complete system of three orthogonal discrete time-space martingales, the first a random walk converging to a Brownian motion; the second, another random walk, independent of the first one, converging to a Poisson process. The solution of this discrete BSDEJ is shown to weakly converge to the solution of the continuous time BSDEJ. An application to partial integro-differential equations is given.
lejay-mordecki-torres-v3.pdf (315.98 Ko) Télécharger le fichier
inria-00357992 , version 1 (02-02-2009)
inria-00357992 , version 2 (25-03-2010)
inria-00357992 , version 3 (09-09-2013)
inria-00357992 , version 4 (18-09-2014)
  • HAL Id : inria-00357992 , version 3
Antoine Lejay, Ernesto Mordecki, Soledad Torres. Numerical approximation of Backward Stochastic Differential Equations with Jumps. [Research Report] 2014, pp.32. ⟨inria-00357992v3⟩
689 Consultations
1496 Téléchargements
