A Stochastic Collocation Method for Elliptic Partial Differential Equations with Random Input Data, SIAM Journal on Numerical Analysis, vol.45, issue.3, pp.1005-1034, 2007. ,
DOI : 10.1137/050645142
??quation de transport. Th??orie spectrale et approximation de la diffusion, Journ??es ??quations aux d??riv??es partielles, pp.1-10, 1982. ,
DOI : 10.5802/jedp.248
The COUPLEX Test Cases: Nuclear Waste Disposal Simulation, Computational Geosciences, vol.8, issue.2, pp.83-89, 2004. ,
DOI : 10.1023/B:COMG.0000035073.03009.5d
URL : https://hal.archives-ouvertes.fr/hal-01315461
Probabilistic interpretation and random walk on spheres algorithms for the Poisson-Boltzmann equation in molecular dynamics, ESAIM: Mathematical Modelling and Numerical Analysis, vol.44, issue.5, 2010. ,
DOI : 10.1051/m2an/2010050
URL : https://hal.archives-ouvertes.fr/inria-00459411
Diffusion Models for Population Dynamics Incorporating Individual Behavior at Boundaries: Applications to Refuge Design, Theoretical Population Biology, vol.55, issue.2, pp.189-207, 1999. ,
DOI : 10.1006/tpbi.1998.1397
A Finite Volume Scheme for the Transport of Radionucleides in Porous Media, Computational Geosciences, vol.8, issue.2, pp.163-172, 2004. ,
DOI : 10.1023/B:COMG.0000035077.63408.71
Flow and Transport in Porous Formations, 1989. ,
DOI : 10.1007/978-3-642-75015-1
Évolution : numérique, transport, of Analyse Mathématique et Calcul Numérique pour les Sciences et Techniques. Masson, 1987. ,
A Random Walk on Rectangles Algorithm, Methodology and Computing in Applied Probability, vol.24, issue.2, pp.135-151, 2006. ,
DOI : 10.1007/s11009-006-7292-3
URL : https://hal.archives-ouvertes.fr/inria-00092424
Simulation of diffusions by means of importance sampling paradigm, The Annals of Applied Probability, vol.20, issue.4, 2010. ,
DOI : 10.1214/09-AAP659
URL : https://hal.archives-ouvertes.fr/inria-00126339
A note on some new perpetuities, Scandinavian Actuarial Journal, vol.52, issue.4, pp.261-270, 2005. ,
DOI : 10.1137/1135018
Nonparametric Density Estimation for Randomly Perturbed Elliptic Problems I: Computational Methods, A Posteriori Analysis, and Adaptive Error Control, SIAM Journal on Scientific Computing, vol.31, issue.4, pp.2935-2995, 2009. ,
DOI : 10.1137/080731670
Nonparametric density estimation for randomly perturbed elliptic problems II: Applications and adaptive modeling, International Journal for Numerical Methods in Engineering, vol.41, issue.6??????7, pp.846-867, 2009. ,
DOI : JCOMP-D-08-00261
Approximation de processus de diffusion à coefficients discontinus en dimension un et applications à la simulation, 2006. ,
On random walk simulation of one-dimensional diffusion processes with discontinuous coefficients, Electronic Journal of Probability, vol.11, issue.0, pp.249-275, 2006. ,
DOI : 10.1214/EJP.v11-311
A Donsker theorem to simulate one-dimensional processes with measurable coefficients, ESAIM: Probability and Statistics, vol.11, pp.301-326, 2007. ,
DOI : 10.1051/ps:2007021
The inverse EEG and MEG problems: The adjoint state approach I: The continuous case, 1999. ,
URL : https://hal.archives-ouvertes.fr/inria-00077112
Simulation du mouvement brownien et des diffusions, 1992. ,
URL : https://hal.archives-ouvertes.fr/tel-00523258
Elliptic Partial Differential Equations of Second Order, 1998. ,
The diffusion limit of transport equations derived from velocity-jump processes, SIAM J. Appl. Math, vol.61, issue.3, pp.751-775, 2000. ,
A Feynman???Kac path-integral implementation for Poisson???s equation using an h-conditioned Green???s function, 3rd IMACS Seminar on Monte Carlo Methods?MCM, pp.3-6347, 2001. ,
DOI : 10.1016/S0378-4754(02)00224-0
Numerical solution of stochastic differential equations, 1992. ,
Ural'ceva. Solvability of diffraction problems in the classical sense, Trudy Mat. Inst. Steklov, vol.92, pp.116-146, 1966. ,
One ??? dimensional stochastic differential equations involving the local times of the unknown process, Stochastic Analysis and Applications, pp.51-82, 1985. ,
DOI : 10.1512/iumj.1975.24.24047
Méthodes probabilistes pour l'homogénéisation des opérateurs sous forme-divergence : cas linéaires et semi-linéaires, 2000. ,
Computing the principal eigenvalue of the Laplace operator by a stochastic method, Mathematics and Computers in Simulation, vol.73, issue.6, pp.351-363, 2006. ,
DOI : 10.1016/j.matcom.2006.06.011
URL : https://hal.archives-ouvertes.fr/inria-00092408
Computing the principal eigenelements of some linear operators using a branching Monte Carlo method, Journal of Computational Physics, vol.227, issue.23, pp.9794-9806, 2008. ,
DOI : 10.1016/j.jcp.2008.07.018
URL : https://hal.archives-ouvertes.fr/hal-01479830
A scheme for simulating one-dimensional diffusion processes with discontinuous coefficients, The Annals of Applied Probability, vol.16, issue.1, pp.107-139, 2006. ,
DOI : 10.1214/105051605000000656
URL : https://hal.archives-ouvertes.fr/inria-00000410
Markov Jump Processes Approximating a Nonsymmetric Generalized Diffusion, 2008. ,
Réduction de variance pour l'intégration numérique et pour le calcul critique en transport neutronique, 2001. ,
On a Monte Carlo method for neutron transport criticality computations, IMA Journal of Numerical Analysis, vol.26, issue.4, pp.657-685, 2006. ,
DOI : 10.1093/imanum/drl008
URL : https://hal.archives-ouvertes.fr/hal-01479840
Interprétations probabilistes d'opérateurs sous forme divergence et analyse de méthodes numériques associées, 2004. ,
Discr??tisation d'??quations diff??rentielles stochastiques unidimensionnelles ?? g??n??rateur sous forme divergence avec coefficient discontinu, Comptes Rendus Mathematique, vol.342, issue.1, pp.51-56, 2006. ,
DOI : 10.1016/j.crma.2005.10.025
Monte Carlo Methods for Calculating Some Physical Properties of Large Molecules, SIAM Journal on Scientific Computing, vol.26, issue.1, pp.339-357, 2004. ,
DOI : 10.1137/S1064827503422221
Simulation of a space-time bounded diffusion, The Annals of Applied Probability, vol.9, issue.3, pp.732-779, 1999. ,
DOI : 10.1214/aoap/1029962812
Some Continuous Monte Carlo Methods for the Dirichlet Problem, The Annals of Mathematical Statistics, vol.27, issue.3, pp.569-589, 1956. ,
DOI : 10.1214/aoms/1177728169
Biased movement at a boundary and conditional occupancy times for diffusion processes, Journal of Applied Probability, vol.52, issue.53, pp.557-580, 2003. ,
A Generalized Taylor???Aris Formula and Skew Diffusion, Multiscale Modeling & Simulation, vol.5, issue.3, pp.786-801, 2006. ,
DOI : 10.1137/050642770
Méthodes Numériques Probabilistes pour la Résolution d'Équations du Transport et pour l'Évaluation d'Options Exotiques, 1997. ,
Diffusion semigroups corresponding to uniformly elliptic divergence form operators, Séminaire de Probabilités XXII, pp.316-347, 1988. ,
DOI : 10.2307/2372841
Calculation of Diffusive Shock Acceleration of Charged Particles by Skew Brownian Motion, The Astrophysical Journal, vol.541, issue.1, pp.428-435, 2000. ,
DOI : 10.1086/309429
Campus scientifique, BP 239, 54506 Vandoeuvre-lès- Nancy CEDEX, France E-mail address: Antoine.Lejay@iecn.u-nancy.fr ISITV ,
