Asymptotics in the random assignment problem, Probability Theory and Related Fields, vol.8, issue.4, pp.507-534, 1992. ,
DOI : 10.1007/BF01192719
A survey of max-type recursive distributional equations, The Annals of Applied Probability, vol.15, issue.2, pp.1047-1110, 2005. ,
DOI : 10.1214/105051605000000142
The Objective Method: Probabilistic Combinatorial Optimization and Local Weak Convergence, 2003. ,
DOI : 10.1007/978-3-662-09444-0_1
Bivariate uniqueness in the logistic recursive distributional equation, 2002. ,
Max-Product for Maximum Weight Matching: Convergence, Correctness, and LP Duality, IEEE Transactions on Information Theory, vol.54, issue.3, 2008. ,
DOI : 10.1109/TIT.2007.915695
Convergence of probability measures, Wiley Series in Probability and Statistics, 1999. ,
DOI : 10.1002/9780470316962
Constructive bounds and exact expectations for the random assignment problem, Random Structures and Algorithms, vol.8, issue.2, pp.113-144, 1999. ,
DOI : 10.1002/(SICI)1098-2418(199909)15:2<113::AID-RSA1>3.0.CO;2-S
On linear programs with random costs, Mathematical Programming, vol.8, issue.1, pp.3-16, 1986. ,
DOI : 10.1007/BF01589437
Theoretical Improvements in Algorithmic Efficiency for Network Flow Problems, Journal of the ACM, vol.19, issue.2, pp.248-264, 1972. ,
DOI : 10.1145/321694.321699
A Lower Bound on the Expected Cost of an Optimal Assignment, Mathematics of Operations Research, vol.18, issue.2, pp.267-274, 1993. ,
DOI : 10.1287/moor.18.2.267
An algorithm to solve them ??n assignment problem in expected timeO(mn logn), Networks, vol.1, issue.2, pp.143-152, 1980. ,
DOI : 10.1002/net.3230100205
Certain expected values in the random assignment problem, Operations Research Letters, vol.14, issue.4, pp.207-214, 1993. ,
DOI : 10.1016/0167-6377(93)90071-N
A proof of Parisi?s conjecture on the random assignment problem, Probability Theory and Related Fields, vol.128, issue.3, pp.419-440, 2004. ,
DOI : 10.1007/s00440-003-0308-9
On the solution of the random link matching problems, Journal de Physique, vol.48, issue.9, pp.1451-1459, 1987. ,
DOI : 10.1051/jphys:019870048090145100
Proofs of the Parisi and Coppersmith-Sorkin random assignment conjectures, Random Structures and Algorithms, vol.26, issue.4, pp.413-444, 2005. ,
DOI : 10.1002/rsa.20084
Asymptotic properties of random assignment problems, 1992. ,
Probabilistic reasoning in intelligent systems: Networks of plausible inference, 1988. ,
On the Expected Value of a Random Assignment Problem, SIAM Journal on Computing, vol.8, issue.3, pp.440-442, 1979. ,
DOI : 10.1137/0208036
Generalized belief propagation, Mitsubishi Elect. Res. Lab, 2000. ,
Proof of Lemma 4.1. The proof of Lemma 4.1 lays upon two technical lemmas stated below. Essentially, the picture is the following: when i gets large ,
