Implicit Linear Systems, 1991. ,
DOI : 10.1007/BFb0044363
Structure of Expansion-Contraction Matrices in the Inclusion Principle for Dynamic Systems, SIAM Journal on Matrix Analysis and Applications, vol.21, issue.4, pp.1136-1155, 2000. ,
DOI : 10.1137/S0895479898340548
Adaptive simulated annealing for optimization in signal processing applications, Signal Processing, vol.79, issue.1, pp.117-128, 1999. ,
DOI : 10.1016/S0165-1684(99)00084-5
On stability and performance of sampled-data systems subject to wordlength constraint, IEEE Transactions on Automatic Control, vol.39, issue.12, pp.2476-2481, 1994. ,
DOI : 10.1109/9.362844
Parametrizations in Control, Estimation and Filtering Probems, 1993. ,
An efficient structure for finite precision implementation of digital systems, Information, Communications and Signal Processing Fifth International Conference on, pp.564-568, 2005. ,
Analyse et synthèse de l'implémentation de lois de contrôle-commande en précision finie ( ´ Etude dans le cadre des applications automobiles sur calculateur embarquée ), 2006. ,
Designing Low Parametric Sensitivity FWL Realizations of LTI Controllers/Filters within the Implicit State-Space Framework, Proceedings of the 44th IEEE Conference on Decision and Control, pp.5192-5197, 2005. ,
DOI : 10.1109/CDC.2005.1582986
URL : https://hal.archives-ouvertes.fr/hal-01317245
IMPLICIT STATE-SPACE REPRESENTATION : A UNIFYING FRAMEWORK FOR FWL IMPLEMENTATION OF LTI SYSTEMS, Proc. of the 16th IFAC World Congress, 2005. ,
DOI : 10.3182/20050703-6-CZ-1902.00048
URL : https://hal.archives-ouvertes.fr/hal-01317235
Low parametric closed-loop sensitivity realizations using fixed-point and floating-point arithmetic, Proc. European Control Conference (ECC'07), 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-01317344
A Unifying Framework for Finite Wordlength Realizations, IEEE Transactions on Circuits and Systems I: Regular Papers, vol.54, issue.8, 2007. ,
DOI : 10.1109/TCSI.2007.902408
URL : https://hal.archives-ouvertes.fr/hal-01317352
Roundoff noise analysis of finite wordlength realizations with the implicit state-space framework, 15th European Signal Processing Conference (EUSIPOC'07), 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00459286
Minimum uncorrelated unit noise in state-space digital filtering, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.25, issue.4, pp.273-281, 1977. ,
DOI : 10.1109/TASSP.1977.1162971
Overlapping decompositions, expansions, and contractions of dynamic systems, Large Scale Syst, vol.1, pp.29-38, 1980. ,
An inclusion principle for dynamic systems, IEEE Transactions on Automatic Control, vol.29, issue.3, pp.244-249, 1984. ,
DOI : 10.1109/TAC.1984.1103486
Adaptive simulated annealing (ASA): Lessons learned, Control and Cybernetics, vol.25, issue.1, pp.33-54, 1996. ,
Digital Controller Implementation and Fragility: A Modern Perspective, 2001. ,
DOI : 10.1007/978-1-4471-0265-6
Improved eigenvalue sensitivity for finite-precision digital controller realisations via orthogonal Hermitian transform, IEE Proc. Control Theory and Appl, vol.150, issue.4, pp.365-375, 2003. ,
An H-infinity-based control design methodology dedicated to the active control of vehicle longitudinal oscillations, IEEE Transactions on Control Systems Technology, vol.11, issue.6, pp.948-956, 2003. ,
DOI : 10.1109/TCST.2003.815552
URL : https://hal.archives-ouvertes.fr/hal-01307329
On the structure of digital controllers with finite word length consideration, IEEE Trans. on Autom. Control, vol.43, issue.5, pp.689-693, 1998. ,
A Polynomial-Operator-Based DFIIt Structure for IIR Filters, IEEE Transactions on Circuits and Systems II: Express Briefs, vol.51, issue.3, pp.147-151, 2004. ,
DOI : 10.1109/TCSII.2003.822439
On the Generalized DFIIt Structure and its State???Space Realization in Digital Filter Implementation, IEEE Transactions on Circuits and Systems I: Regular Papers, vol.51, issue.4, pp.769-778, 2004. ,
DOI : 10.1109/TCSI.2004.823652
Synthesis of minimum roundoff noise fixed point digital filters, IEEE Transactions on Circuits and Systems, p.23, 1976. ,
DOI : 10.1109/TCS.1976.1084254
Digital estimation and control with a new discrete time operator, [1991] Proceedings of the 30th IEEE Conference on Decision and Control, pp.1631-1632, 1991. ,
DOI : 10.1109/CDC.1991.261682
Design of sensitivity and round-off noise optimal state-space discrete systems, International Journal of Circuit Theory and Applications, vol.26, issue.1, pp.39-46, 1984. ,
DOI : 10.1002/cta.4490120104
Decentralized Control of Complex Systems, 1991. ,
Reduction of controller fragility by pole sensitivity minimization, IEEE Transactions on Automatic Control, vol.46, issue.2, pp.320-325, 2001. ,
DOI : 10.1109/9.905702
framework, International Journal of Control, vol.73, issue.2, pp.166-176, 2000. ,
DOI : 10.1080/002071700219876
Statistical analysis of amplitude-quantized sampled-data systems, Transactions of the American Institute of Electrical Engineers, Part II: Applications and Industry, vol.79, issue.6, pp.555-568, 1960. ,
DOI : 10.1109/TAI.1961.6371702
Unsolved Problems in Mathematical Systems and Control Theory , chapter Stable controller coefficient perturbation in floating point implementation, pp.280-284, 2004. ,
An improved closed-loop stability related measure for finite-precision digital controller realizations, IEEE Transactions on Automatic Control, vol.46, issue.7, pp.1162-1166, 2001. ,
DOI : 10.1109/9.935076
A unified closed-loop stability measure for finite-precision digital controller realizations implemented in different representation schemes, IEEE Trans. Automatic Control, vol.48, issue.5, pp.816-823, 2003. ,
Robust and Optimal Control Whidborne A Algorithms and numerical values Input: u : real Output: y : real Data: xn : array of four reals Data: xnp : array of four reals Data: Acc : real begin, Acc ? xn, issue.11, 1996. ,
) ? Acc + u * ?1991, ?0, vol.86022115571, issue.4 ,
) ? Acc + u * 5980 ,
