New interface
Conference papers
Almost-Uniform Sampling of Points on High-Dimensional Algebraic Varieties
Abstract : We consider the problem of uniform sampling of points on an algebraic variety. Specifically, we develop a randomized algorithm that, given a small set of multivariate polynomials over a sufficiently large finite field, produces a common zero of the polynomials almost uniformly at random. The statistical distance between the output distribution of the algorithm and the uniform distribution on the set of common zeros is polynomially small in the field size, and the running time of the algorithm is polynomial in the description of the polynomials and their degrees provided that the number of the polynomials is a constant.
Complete list of metadata
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/inria-00359299
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Friday, February 6, 2009 - 3:06:41 PM
Last modification on : Monday, October 2, 2017 - 4:06:04 PM
Long-term archiving on: : Tuesday, June 8, 2010 - 10:00:40 PM
cheraghchi_new.pdf
Identifiers
  • HAL Id : inria-00359299, version 1
  • ARXIV : 0902.1254
Collections
Citation
Mahdi Cheraghchi, Amin Shokrollahi. Almost-Uniform Sampling of Points on High-Dimensional Algebraic Varieties. 26th International Symposium on Theoretical Aspects of Computer Science STACS 2009, Feb 2009, Freiburg, Germany. pp.277-288. ⟨inria-00359299⟩
Share
Metrics
Record views
33
Files downloads
105
