An Order on Sets of Tilings Corresponding to an Order on Languages
Traditionally a tiling is defined with a finite number of finite forbidden patterns. We can generalize this notion considering any set of patterns. Generalized tilings defined in this way can be studied with a dynamical point of view, leading to the notion of subshift. In this article we establish a correspondence between an order on subshifts based on dynamical transformations on them and an order on languages of forbidden patterns based on computability properties.
Mathématique discrète [cs.DM]
