we compute the array P Comp of size |P airs|, such that, for Comp[P airs[l].?]] (where P airs[l].? is the second member of the pair of integers in position l of P airs). Fourth. Using P airs and P Comp, we select the (k ? n < )-th smallest key suffix s x and all the key suffixes equal to s x according to the total order ? (where n < is the number of suffixes of S that are lexicographically smaller than each suffix in R, known since Sec, Third. By scanning P airs and Comp at the same time ,
The input/output complexity of sorting and related problems, Communications of ACM, 1988. ,
DOI : 10.1145/48529.48535
URL : https://hal.archives-ouvertes.fr/inria-00075827
Time bounds for selection, Journal of Computer and System Sciences, vol.7, issue.4, pp.448-61, 1973. ,
DOI : 10.1016/S0022-0000(73)80033-9
Optimal Time Minimal Space Selection Algorithms, Journal of the ACM, vol.28, issue.3, pp.454-461, 1981. ,
DOI : 10.1145/322261.322264
Optimal suffix tree construction with large alphabets, Proceedings 38th Annual Symposium on Foundations of Computer Science, pp.137-143, 1997. ,
DOI : 10.1109/SFCS.1997.646102
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.45.4336
Overcoming the memory bottleneck in suffix tree construction, Proceedings 39th Annual Symposium on Foundations of Computer Science (Cat. No.98CB36280), 1998. ,
DOI : 10.1109/SFCS.1998.743441
Optimal suffix selection, Proceedings of the thirty-ninth annual ACM symposium on Theory of computing , STOC '07, 2007. ,
DOI : 10.1145/1250790.1250840
URL : https://hal.archives-ouvertes.fr/inria-00359742
Cache-oblivious algorithms, Proc. 40th Annual Symp. on Foundations of Computer Science (FOCS 1999), pp.285-297, 1999. ,
Optimal parallel algorithms for string matching, Information and Control, vol.67, issue.1-3, pp.144-157, 1985. ,
DOI : 10.1016/S0019-9958(85)80031-0
A Space-Economical Suffix Tree Construction Algorithm, Journal of the ACM, vol.23, issue.2, pp.262-272, 1976. ,
DOI : 10.1145/321941.321946
Algorithms and Data Structures for External Memory, Foundations and Trends?? in Theoretical Computer Science, vol.2, issue.4, 2007. ,
DOI : 10.1561/0400000014
Linear pattern matching algorithms, 14th Annual Symposium on Switching and Automata Theory (swat 1973), 1973. ,
DOI : 10.1109/SWAT.1973.13
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.474.9582
