Crown Structures for Vertex Cover Kernelization, Theory of Computing Systems, vol.41, issue.3, pp.411-430, 2007. ,
DOI : 10.1007/s00224-007-1328-0
-Plex Problem, Operations Research, vol.59, issue.1, 2008. ,
DOI : 10.1287/opre.1100.0851
URL : https://hal.archives-ouvertes.fr/hal-00823716
Computational, Integrative, and Comparative Methods for the Elucidation of Genetic Coexpression Networks, Journal of Biomedicine and Biotechnology, vol.2005, issue.2, pp.172-180, 2005. ,
DOI : 10.1155/JBB.2005.172
A Local-Ratio Theorem for Approximating the Weighted Vertex Cover Problem, Ann. of Discrete Math, vol.25, pp.27-45, 1985. ,
DOI : 10.1016/S0304-0208(08)73101-3
A Linear Kernel for Planar Feedback Vertex Set, Proc. 3rd IWPEC, pp.160-171, 2008. ,
DOI : 10.1007/978-3-540-79723-4_16
Reduction Algorithms for Graphs of Small Treewidth, Information and Computation, vol.167, issue.2, pp.86-119, 2001. ,
DOI : 10.1006/inco.2000.2958
Vertex Cover: Further Observations and Further Improvements, Journal of Algorithms, vol.41, issue.2, pp.280-301, 2001. ,
DOI : 10.1006/jagm.2001.1186
URL : http://anyserver.cityu.edu.hk/weijia/publication/vertex_cover.pdf
Complex trait analysis of gene expression uncovers polygenic and pleiotropic networks that modulate nervous system function, Nature Genetics, vol.143, issue.3, pp.233-242, 2005. ,
DOI : 10.1093/bioinformatics/btg112
Crown reductions for the Minimum Weighted Vertex Cover problem, Discrete Applied Mathematics, vol.156, issue.3, pp.292-312, 2008. ,
DOI : 10.1016/j.dam.2007.03.026
Parameterized Complexity Theory, 2006. ,
A more effective linear kernelization for cluster editing, Theor. Comput. Sci, 2008. ,
Invitation to data reduction and problem kernelization, ACM SIGACT News, vol.38, issue.1, pp.31-45, 2007. ,
DOI : 10.1145/1233481.1233493
Linear Problem Kernels for NP-Hard Problems on Planar Graphs, Proc. 34th ICALP, pp.375-386, 2007. ,
DOI : 10.1007/978-3-540-73420-8_34
On the induced matching problem, Journal of Computer and System Sciences, vol.77, issue.6, 2009. ,
DOI : 10.1016/j.jcss.2010.09.001
URL : https://hal.archives-ouvertes.fr/hal-00231081
Vertex cover might be hard to approximate to within <mml:math altimg="si1.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mn>2</mml:mn><mml:mo>???</mml:mo><mml:mi>??</mml:mi></mml:math>, Journal of Computer and System Sciences, vol.74, issue.3, pp.335-349, 2008. ,
DOI : 10.1016/j.jcss.2007.06.019
Algorithms column, ACM SIGACT News, vol.33, issue.2, pp.31-33, 2002. ,
DOI : 10.1145/564585.564598
Isolation Concepts for Enumerating Dense Subgraphs, Proc. 13th COCOON, pp.140-150, 2007. ,
DOI : 10.1007/978-3-540-73545-8_16
Vertex packings: Structural properties and algorithms, Mathematical Programming, vol.5, issue.1, pp.232-248, 1975. ,
DOI : 10.1007/BF01580444
Invitation to Fixed-Parameter Algorithms, 2006. ,
DOI : 10.1093/acprof:oso/9780198566076.001.0001
Fast fixed-parameter tractable algorithms for nontrivial generalizations of Vertex Cover, Discrete Appl. Math, vol.152, pp.1-3229, 2005. ,
Looking at the stars, Theoretical Computer Science, vol.351, issue.3, pp.437-445, 2006. ,
DOI : 10.1016/j.tcs.2005.10.009
A graph???theoretic generalization of the clique concept*, The Journal of Mathematical Sociology, vol.33, issue.1, pp.139-154, 1978. ,
DOI : 10.1002/bs.3830110409
An Improved Parameterized Algorithm for a Generalized Matching Problem, Proc. 5th TAMC, pp.212-222, 2008. ,
DOI : 10.1007/978-3-540-79228-4_19
