Deciding Unambiguity and Sequentiality of Polynomially Ambiguous Min-Plus Automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper solves the unambiguity and the sequentiality problem for polynomially ambiguous min-plus automata. This result is proved through a decidable algebraic characterization involving so-called metatransitions and an application of results from the structure theory of finite semigroups. It is noteworthy that the equivalence problem is known to be undecidable for polynomially ambiguous automata.
49-kirsten.pdf (226.29 Ko) Télécharger le fichier
inria-00360205 , version 1 (10-02-2009)
  • HAL Id : inria-00360205 , version 1
Daniel Kirsten, Sylvain Lombardy. Deciding Unambiguity and Sequentiality of Polynomially Ambiguous Min-Plus Automata. 26th International Symposium on Theoretical Aspects of Computer Science STACS 2009, Feb 2009, Freiburg, Germany. pp.589-600. ⟨inria-00360205⟩
284 Consultations
440 Téléchargements
