Kernelization algorithms for d-hitting set problems, LNCS, vol.4619, pp.434-445, 2007. ,
Proof verification and the hardness of approximation problems, Journal of the ACM, vol.45, issue.3, pp.501-555, 1998. ,
DOI : 10.1145/278298.278306
A 2-Approximation Algorithm for the Undirected Feedback Vertex Set Problem, SIAM Journal on Discrete Mathematics, vol.12, issue.3, pp.289-297, 1999. ,
DOI : 10.1137/S0895480196305124
A cubic kernel for feedback vertex set, STACS, pp.320-331, 2007. ,
On problems without polynomial kernels (extended abstract), LNCS, vol.5125, issue.1, pp.563-574, 2008. ,
On Fixed-Parameter Tractability and Approximability of NP Optimization Problems, Journal of Computer and System Sciences, vol.54, issue.3, pp.465-474, 1997. ,
DOI : 10.1006/jcss.1997.1490
Fixed-Parameter Approximation: Conceptual Framework and Approximability Results, Lecture Notes in Computer Science, vol.4169, pp.96-108, 2006. ,
DOI : 10.1007/11847250_9
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.219.2987
Vertex Cover: Further Observations and Further Improvements, Journal of Algorithms, vol.41, issue.2, pp.280-301, 2001. ,
DOI : 10.1006/jagm.2001.1186
URL : http://anyserver.cityu.edu.hk/weijia/publication/vertex_cover.pdf
Intersection theorems for systems of sets, J. London Math. Soc, vol.35, pp.85-90, 1960. ,
Generalized first-order spectra and polynomial-time recognizable sets, Complexity of Computation of SIAM-AMS Proceedings, pp.43-73, 1974. ,
Improved Approximation Algorithms for Minimum Weight Vertex Separators, SIAM Journal on Computing, vol.38, issue.2, pp.629-657, 2008. ,
DOI : 10.1137/05064299X
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.597.5634
Parameterized Complexity Theory (Texts in Theoretical Computer Science. An EATCS Series), 2006. ,
Infeasibility of instance compression and succinct PCPs for NP, Proceedings of the fourtieth annual ACM symposium on Theory of computing, STOC 08, pp.133-142, 2008. ,
DOI : 10.1145/1374376.1374398
Improved Approximation Algorithms for the Vertex Cover Problem in Graphs and Hypergraphs, SIAM Journal on Computing, vol.31, issue.5, pp.1608-1623, 2002. ,
DOI : 10.1137/S0097539700381097
On Syntactic versus Computational Views of Approximability, SIAM Journal on Computing, vol.28, issue.1, pp.164-191, 1998. ,
DOI : 10.1137/S0097539795286612
Logical definability of NP optimization problems, Inf. Comput, vol.115, issue.2, pp.321-353, 1994. ,
Approximation properties of NP minimization classes, J. Comput. Syst. Sci, vol.50, issue.3, pp.391-411, 1995. ,
A Polynomial Approximation Algorithm for the Minimum Fill-In Problem, SIAM Journal on Computing, vol.30, issue.4, pp.1067-1079, 2000. ,
DOI : 10.1137/S0097539798336073
Invitation to Fixed Parameter Algorithms (Oxford Lecture Series in Mathematics and Its Applications), 2006. ,
Smaller Kernels for Hitting Set Problems of Constant Arity, LNCS, vol.3162, pp.121-126, 2004. ,
DOI : 10.1007/978-3-540-28639-4_11
Computational Complexity, 1993. ,
Papadimitriou and Mihalis Yannakakis. Optimization, approximation, and complexity classes, J. Comput. Syst. Sci, vol.43, issue.3, pp.425-440, 1991. ,
