Reports
Combining CCSL and Esterel to specify and verify time requirements
Charles André 1 Frédéric Mallet 1
1 AOSTE - Models and methods of analysis and optimization for systems with real-time and embedding constraints
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Paris-Rocquencourt, Laboratoire I3S - COMRED - COMmunications, Réseaux, systèmes Embarqués et Distribués
Abstract : The UML Profile for Modeling and Analysis of Real-Time and Embedded (RTE) systems has recently been adopted by the OMG. Its Time Model extends the informal and simplistic Simple Time package proposed by UML2 and offers a broad range of capabilities required to model RTE systems including both discrete/dense and chronometric/logical time. MARTE OMG specification introduces a Time Structure inspired from Time models of the concurrency theory and proposes a new clock constraint specification language (CCSL) to specify, within the context of UML, logical and chronometric time constraints. This paper introduces the formal semantics of CCSL clock constraints and proposes a process to use CCSL both as a high-level specification language for UML models and as a golden model to verify the conformance of implementations. A digital filtering video application is used as a running example to support the discussion. The application is first formally specified with CCSL and the specification is refined based on feedback from the CCSL-dedicated simulator. In a second phase, an Esterel program of the application is considered. This program is instrumented with observers derived from the CCSL specification. Esterel Studio formal verification facilities are then used to check the conformity of the Esterel implementation with the CCSL specification. A specific library of Esterel observers has been built for this purpose.
Document type :
Reports
Complete list of metadata
Cited literature [28 references]  Display  Hide  Download
https://hal.inria.fr/inria-00360528
Contributor : Frédéric Mallet Connect in order to contact the contributor
Submitted on : Thursday, March 26, 2009 - 12:07:50 PM
Last modification on : Friday, January 21, 2022 - 3:18:18 AM
Long-term archiving on: : Wednesday, September 22, 2010 - 12:36:00 PM
File
RR-6839.pdf
Identifiers
  • HAL Id : inria-00360528, version 2
Collections
Citation
Charles André, Frédéric Mallet. Combining CCSL and Esterel to specify and verify time requirements. [Research Report] RR-6839, INRIA. 2009. ⟨inria-00360528v2⟩
Share
Metrics
Record views
216
Files downloads
180
