Geometric applications of a matrix-searching algorithm, Algorithmica, vol.9, issue.1-4, pp.195-208, 1987. ,
DOI : 10.1007/BF01840359
Let Sleeping Files Lie: Pattern Matching in Z-Compressed Files, Journal of Computer and System Sciences, vol.52, issue.2, pp.299-307, 1996. ,
DOI : 10.1006/jcss.1996.0023
Inplace 2D matching in compressed images, Proc. of the 14th annual ACM-SIAM Symposium On Discrete AlgorithmsSODA), pp.853-862, 2003. ,
DOI : 10.1016/S0196-6774(03)00088-9
Efficient Parallel Algorithms for String Editing and Related Problems, SIAM Journal on Computing, vol.19, issue.5, pp.968-988, 1990. ,
DOI : 10.1137/0219066
Matching for Run-Length Encoded Strings, Journal of Complexity, vol.15, issue.1, pp.4-16, 1999. ,
DOI : 10.1006/jcom.1998.0493
Edit distance of run-length encoded strings, Information Processing Letters, vol.83, issue.6, pp.307-314, 2001. ,
DOI : 10.1016/S0020-0190(02)00215-6
Fast and compact regular expression matching, Theoretical Computer Science, vol.409, issue.3, 2005. ,
DOI : 10.1016/j.tcs.2008.08.042
An improved algorithm for computing the edit distance of run-length coded strings, Information Processing Letters, vol.54, issue.2, pp.93-96, 1995. ,
DOI : 10.1016/0020-0190(95)00005-W
Window Subsequence Problems for Compressed Texts, Proc. of the 1st symp. on Computer Science in Russia (CSR), pp.127-136, 2006. ,
DOI : 10.1007/11753728_15
A Subquadratic Sequence Alignment Algorithm for Unrestricted Scoring Matrices, SIAM Journal on Computing, vol.32, issue.6, pp.1654-1673, 2003. ,
DOI : 10.1137/S0097539702402007
URL : https://hal.archives-ouvertes.fr/hal-00619573
Algorithms on Strings, Trees, and Sequences, Computer Science and Computational Biology, 1997. ,
DOI : 10.1017/CBO9780511574931
Approximate String Matching over Ziv???Lempel Compressed Text, Proc. of the 11th symposium on Combinatorial Pattern Matching (CPM), pp.195-209, 2000. ,
DOI : 10.1007/3-540-45123-4_18
Lempel-Ziv parsing and sublinear-size index structures for string matching, Proc. of the 3rd South American Workshop on String Processing (WSP), pp.141-155, 1996. ,
Pattern-matching for strings with short descriptions, Proc. of the 6th symposium on Combinatorial Pattern Matching (CPM), pp.205-214, 1995. ,
DOI : 10.1007/3-540-60044-2_44
Approximation algorithms for grammar-based compression, Proc. of the 13th annual ACM-SIAM Symposium On Discrete AlgorithmsSODA), pp.205-212, 2002. ,
Binary codes capable of correcting deletions, insertions and reversals, Soviet Physics Doklady, vol.10, issue.8, pp.707-710, 1966. ,
Processing Compressed Texts: A Tractability Border, Proc. of the 18th symposium on Combinatorial Pattern Matching (CPM), pp.228-240, 2007. ,
DOI : 10.1007/978-3-540-73437-6_24
Querying and Embedding Compressed Texts, Proc. of the 31st international symposium on Mathematical Foundations of Computer Science (MFCS), pp.681-692, 2006. ,
DOI : 10.1007/11821069_59
Approximate matching of run-length compressed strings, Proc. of the 12th Symposium On Combinatorial Pattern Matching (CPM), pp.1-13, 1999. ,
A text compression scheme that allows fast searching directly in the compressed file, Proc of the 5th Symposium On Combinatorial Pattern Matching (CPM), pp.31-49, 1994. ,
A faster algorithm computing string edit distances, Journal of Computer and System Sciences, vol.20, issue.1, 1980. ,
DOI : 10.1016/0022-0000(80)90002-1
An improved pattern matching algorithm for strings in terms of straight-line programs, Proc. of the 8th symposium on Combinatorial Pattern Matching (CPM), pp.1-11, 1997. ,
DOI : 10.1007/3-540-63220-4_45
Speeding Up HMM Decoding and Training by Exploiting Sequence Repetitions, Proc. of the 18th symposium on Combinatorial Pattern Matching (CPM), pp.4-15, 2007. ,
DOI : 10.1007/978-3-540-73437-6_4
Faster approximate string matching over compressed text, Proceedings DCC 2001. Data Compression Conference, pp.459-468, 2001. ,
DOI : 10.1109/DCC.2001.917177
Application of Lempel???Ziv factorization to the approximation of grammar-based compression, Theoretical Computer Science, vol.302, issue.1-3, pp.211-222, 2003. ,
DOI : 10.1016/S0304-3975(02)00777-6
All Highest Scoring Paths in Weighted Grid Graphs and Their Application to Finding All Approximate Repeats in Strings, SIAM Journal on Computing, vol.27, issue.4, pp.972-992, 1998. ,
DOI : 10.1137/S0097539795288489
Byte Pair encoding: A text compression scheme that accelerates pattern matching, 1999. ,
Speeding Up Pattern Matching by Text Compression, Proc. of the 4th Italian Conference Algorithms and Complexity (CIAC), pp.306-315, 2000. ,
DOI : 10.1007/3-540-46521-9_25
Faster subsequence recognition in compressed strings, Journal of Mathematical Sciences, vol.24, issue.6 ,
DOI : 10.1007/s10958-009-9396-0
All Semi-local Longest Common Subsequences in Subquadratic Time, Proc. of the 1st Computer Science symposium in Russia (CSR), pp.352-363, 2006. ,
DOI : 10.1007/11753728_36
The String-to-String Correction Problem, Journal of the ACM, vol.21, issue.1, pp.168-173, 1974. ,
DOI : 10.1145/321796.321811
On the complexity of finite sequences, IEEE Transactions on Information Theory, vol.22, issue.1, pp.75-81, 1976. ,
A universal algorithm for sequential data compression, IEEE Transactions on Information Theory, vol.23, issue.3, pp.337-343, 1977. ,
DOI : 10.1109/TIT.1977.1055714
