Reports
A Utility-based Framework for Assessing Fairness Schemes in Ad-Hoc Networks
Emmanouil Dramitinos 1, * Rémi Vannier 1, * Isabelle Guérin-Lassous 1, 2
* Corresponding author
2 RESO - Protocols and softwares for very high-performance network
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
Abstract : Fairness in multihop ad hoc networks has received considerable attention in the literature. A plethora of protocols have been proposed, which compute the ``optimal'' bit rates of the transmitting mobile nodes over short time-scales so that a certain fairness criterion is met. However, there has been limited research on the impact of the varying short-term allocations of these protocols due to nodes mobility on the user-perceived QoS (and social welfare) for services of long duration. In this paper, we introduce a utility-based framework, based on {\em QoS-aware history-dependent} utility functions. These functions quantify the satisfaction that the users of the MANETs obtain from the way their long-lived service sessions are allocated bandwidth, due to the behavior of the fairness protocols proposed for ad hoc networks. Finally, we demonstrate the framework's usefulness, by performing a comparative assessment of the fairness protocol of our previous work with the standard IEEE 802.11.
Complete list of metadata
Cited literature [21 references]  Display  Hide  Download
https://hal.inria.fr/inria-00360848
Contributor : Rémi Vannier Connect in order to contact the contributor
Submitted on : Tuesday, February 17, 2009 - 1:54:06 PM
Last modification on : Saturday, September 11, 2021 - 3:17:25 AM
Long-term archiving on: : Saturday, November 26, 2016 - 5:42:18 AM
File
RR-6843.pdf
Identifiers
  • HAL Id : inria-00360848, version 2
Collections
Citation
Emmanouil Dramitinos, Rémi Vannier, Isabelle Guérin-Lassous. A Utility-based Framework for Assessing Fairness Schemes in Ad-Hoc Networks. [Research Report] RR-6843, INRIA. 2009, pp.15. ⟨inria-00360848v2⟩
Share
Metrics
Record views
313
Files downloads
336
