Bernstein inequality and moderate deviations under strong mixing conditions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper we obtain a Bernstein type inequality for geometrically strongly mixing sequences of bounded random variables. This inequality leads to a moderate deviations prinicple that complements the large deviation result obtained by Bryc and Dembo (1998) under superexponential mixing rates.
luminy02.pdf (243.42 Ko) Télécharger le fichier
inria-00360856 , version 1 (12-02-2009)
  • HAL Id : inria-00360856 , version 1
Florence Merlevède, Magda Peligrad, Emmanuel Rio. Bernstein inequality and moderate deviations under strong mixing conditions. High dimensional probability V : the 5th International Conference (HDP V), May 2008, Luminy, France. pp.273-292. ⟨inria-00360856⟩
3479 Consultations
831 Téléchargements
