Size gradation control of anisotropic meshes. Finite Elements in Analysis and Design, 2009. ,
Multi-Dimensional Continuous Metric for Mesh Adaptation, Proc. of 15th Int. Meshing Rountable, pp.191-214, 2006. ,
DOI : 10.1007/978-3-540-34958-7_12
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.64.5271
On the Choice of Wavespeeds for the HLLC Riemann Solver, SIAM Journal on Scientific Computing, vol.18, issue.6, pp.1553-1570, 1997. ,
DOI : 10.1137/S1064827593260140
Simplified sonic-boom prediction, TP. 1122, Nasa, 1978. ,
A wind-tunnel investigation of the effect of body shape on sonic-boom pressure distributions, 1965. ,
Anisotropic unstructured mesh adaption for flow simulations, International Journal for Numerical Methods in Fluids, vol.59, issue.4, pp.475-491, 1997. ,
DOI : 10.1002/(SICI)1097-0363(19970830)25:4<475::AID-FLD575>3.0.CO;2-6
Approximation by finite element functions using local regularization. Revue Française d'Automatique, Informatique et Recherche Opérationnelle, pp.77-84, 1975. ,
Positivity statements for a mixed-element-volume scheme on fixed and moving grids, Revue europ??enne de m??canique num??rique, vol.15, issue.7-8, pp.767-798, 2006. ,
DOI : 10.3166/remn.15.767-798
Mixed-element-volume MUSCL methods with weak viscosity for steady and unsteady flow calculations, Computers & Fluids, vol.29, issue.1, pp.89-118, 2000. ,
DOI : 10.1016/S0045-7930(98)00059-0
About theoretical and practical impact of mesh adaptations on approximation of functions and of solution of PDE, Int. J. Numer. Meth. Fluids, vol.43, pp.507-516, 2003. ,
Anisotropic Delaunay Mesh Adaptation for Unsteady Simulations, Proc. of 17th Int. Meshing Rountable, pp.177-194, 2008. ,
DOI : 10.1007/978-3-540-87921-3_11
URL : https://hal.archives-ouvertes.fr/hal-00353786
Anisotropic mesh adaptation for CFD computations, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.48-49, pp.48-495068, 2005. ,
DOI : 10.1016/j.cma.2004.11.025
Mesh generation. Application to finite elements, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00073738
Reduction of sonic boom by azimuthal redistribution of overpressure, 6th Aerospace Sciences Meeting, pp.291-298, 1969. ,
DOI : 10.2514/6.1968-159
Tet meshing: construction, optimization and adaptation, Proc. of 8th Int. Meshing Rountable, 1999. ,
3D tetrahedral, unstructured and anisotropic mesh generation with adaptation to natural and multidomain metric, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.48-49, pp.48-494951, 2005. ,
DOI : 10.1016/j.cma.2004.11.020
URL : https://hal.archives-ouvertes.fr/hal-00517639
Sonic boom propagation in a stratified atmosphere with computer program, 1969. ,
Hisac midterm overview of sonic boom issues, Proc. of the 19th international congress on acoustics-ICA, 2007. ,
Quiet spike near field flight test pressure measurement with computational fluid dynamics comparisons, pp.2008-128, 2008. ,
Manual of the ICAO Standard Atmosphere (extended to 80 kilometres) Doc 7488, 1993. ,
Validation of 3d adjoint based error estimation and mesh adaptation for sonic boom reduction, 1150. ,
Towards the ultimate conservative difference scheme i. The quest of monotonicity. Lecture notes in physics, p.163, 1972. ,
3D anisotropic mesh adaptation by mesh modification, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.48-49, pp.48-494915, 2005. ,
DOI : 10.1016/j.cma.2004.11.019
Adaptation de maillage anisotrope 3D multi-´ echelles et cibléè a une fonctionnelle pour la mécanique des fluides. ApplicationàApplication`Applicationà la prédiction haute-fidélité du bang sonique, 2008. ,
Achievement of Global Second Order Mesh Convergence for Discontinuous Flows with Adapted Unstructured Meshes, 18th AIAA Computational Fluid Dynamics Conference, pp.2007-4186, 2007. ,
DOI : 10.2514/6.2007-4186
F-5 Shaped Sonic Boom Demonstrator's Persistence of Boom Shaping Reduction Through Turbulence, 43rd AIAA Aerospace Sciences Meeting and Exhibit, pp.2005-2017, 2005. ,
DOI : 10.2514/6.2005-12
An efficient method for incorporating computational fluid dynamics into sonic boom prediction, 9th Applied Aerodynamics Conference, pp.1991-3275, 1991. ,
DOI : 10.2514/6.1991-3275
Tetrahedral mesh optimisation and adaptivity for steady-state and transient finite element calculations, Computer Methods in Applied Mechanics and Engineering, vol.190, issue.29-30, pp.3771-3796, 2001. ,
DOI : 10.1016/S0045-7825(00)00294-2
Sonic boom technologies and challenges, FAA Civil Supersonic Aircraft Workshop, 2003. ,
Theoretical basis for the finite difference extrapolation of sonic boom signatures, NASA Conference publication 3335, pp.54-67, 1995. ,
Extrapolation of sonic boom signatures from CFD solutions, 40th AIAA Aerospace Sciences Meeting & Exhibit, pp.2002-0922, 2002. ,
DOI : 10.2514/6.2002-922
Approximate Riemann solvers, parameter vectors, and difference schemes, Journal of Computational Physics, vol.43, issue.2, pp.357-372, 1981. ,
DOI : 10.1016/0021-9991(81)90128-5
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.457.5978
Efficient implementation of essentially non-oscillatory shock-capturing schemes, Journal of Computational Physics, vol.77, issue.2, pp.439-471, 1988. ,
DOI : 10.1016/0021-9991(88)90177-5
A New Class of Optimal High-Order Strong-Stability-Preserving Time Discretization Methods, SIAM Journal on Numerical Analysis, vol.40, issue.2, pp.469-491, 2002. ,
DOI : 10.1137/S0036142901389025
Flux vector splitting of the inviscid gasdynamic equations with application to finite-difference methods, Journal of Computational Physics, vol.40, issue.2, pp.263-293, 1981. ,
DOI : 10.1016/0021-9991(81)90210-2
Anisotropic mesh adaptation for 3D flows on structured and unstructured grids, Computer Methods in Applied Mechanics and Engineering, vol.189, issue.4, pp.1205-1230, 2000. ,
DOI : 10.1016/S0045-7825(99)00374-6
Extrapolation of sonic boom pressure signatures by the waveform parameter method, 1972. ,
Application of USM3D for Sonic Boom Prediction by Utilizing a Hybrid Procedure, 46th AIAA Aerospace Sciences Meeting and Exhibit, 2008. ,
DOI : 10.2514/6.2008-129
Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès-Nancy Cedex (France) Unité de recherche INRIA Rennes : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Rhône-Alpes : 655, avenue de l'Europe -38334 Montbonnot Saint-Ismier (France) Unité de recherche, 2004. ,
BP 105 -78153 Le Chesnay Cedex (France) http://www.inria.fr ISSN, pp.249-6399 ,
