Capacity of Multi-antenna Gaussian Channels, European Transactions on Telecommunications, vol.45, issue.6, pp.585-595, 1999. ,
DOI : 10.1002/ett.4460100604
Space-time codes for high data rate wireless communication: performance criterion and code construction, IEEE Transactions on Information Theory, vol.44, issue.2, pp.744-765, 1998. ,
DOI : 10.1109/18.661517
Digital Phase Modulation, 1986. ,
DOI : 10.1007/978-1-4899-2031-7
Space-time coding for Rayleigh fading channels in CPM system, Proc. of Annu. Allerton Conf. Communication, Control, and Computing, 2000. ,
Continuous phase modulated space-time codes, Proc. of IEEE International Symposium on Communication Theory and Applications (ISCTA'05), pp.292-297, 2005. ,
Serially Concatenated Space-Time Coded Continuous Phase Modulated Signals, IEEE Transactions on Wireless Communications, vol.6, issue.10, pp.3487-3492, 2007. ,
DOI : 10.1109/TWC.2007.051004
Externally encoded space-time coded systems with continuous phase frequency shift keying, 2005 International Conference on Wireless Networks, Communications and Mobile Computing ,
DOI : 10.1109/WIRLES.2005.1549652
A decomposition approach to CPM, IEEE Transactions on Information Theory, vol.34, issue.2, pp.260-270, 1988. ,
DOI : 10.1109/18.2634
On the theory of space-time codes for PSK modulation, IEEE Transactions on Information Theory, vol.46, issue.2, pp.524-542, 2000. ,
DOI : 10.1109/18.825816
Burst-Based Orthogonal ST Block Coding for CPM, IEEE Transactions on Wireless Communications, vol.6, issue.4, pp.1208-1212, 2007. ,
DOI : 10.1109/TWC.2007.348314
An Orthogonal Space???Time Coded CPM System With Fast Decoding for Two Transmit Antennas, IEEE Transactions on Information Theory, vol.50, issue.3, pp.486-493, 2004. ,
DOI : 10.1109/TIT.2004.824919
An orthogonal space-time coded partial response CPM system with fast decoding for two transmit antennas, IEEE Transactions on Wireless Communications, vol.4, issue.5, pp.2410-2422, 2005. ,
DOI : 10.1109/TWC.2005.853913
A simple transmit diversity technique for wireless communications, IEEE Journal on Selected Areas in Communications, vol.16, issue.8, pp.1451-1458, 1998. ,
DOI : 10.1109/49.730453
Orthogonal-Like Space–Time-Coded CPM Systems With Fast Decoding for Three and Four Transmit Antennas, Proc. of IEEE Global Telecommunications Conference (GLOBECOM '03), pp.3321-3325, 2003. ,
DOI : 10.1109/TIT.2009.2039058
L2 orthogonal space time code for Continuous Phase Modulation, 2008 IEEE 9th Workshop on Signal Processing Advances in Wireless Communications, pp.6-9, 2008. ,
DOI : 10.1109/SPAWC.2008.4641638
URL : https://hal.archives-ouvertes.fr/inria-00288334
Space-time code design with continuous phase modulation, IEEE Journal on Selected Areas in Communications, vol.21, issue.5, pp.783-792, 2003. ,
DOI : 10.1109/JSAC.2003.810343
An alternative approach to reduced-complexity CPM-receivers, IEEE Journal on Selected Areas in Communications, vol.7, issue.9, pp.1437-1449, 1989. ,
DOI : 10.1109/49.44587
