Journal articles
Inverse Scattering for Soft Fault Diagnosis in Electric Transmission Lines
Qinghua Zhang 1, * Michel Sorine 1 Mehdi Admane 1
* Corresponding author
Abstract : Today's advanced reflectometry methods provide an efficient solution for the diagnosis of electric transmission line hard faults (open and short circuits), but they are much less efficient for soft faults, in particular, for faults resulting in spatially smooth variations of characteristic impedance. This paper attempts to fill an important gap for the application of the inverse scattering transform to reflectometry-based soft fault diagnosis: it clarifies the relationship between the reflection coefficient measured with reflectometry instruments and the mathematical object of the same name defined in the inverse scattering theory, by reconciling finite length transmission lines with the inverse scattering transform defined on the infinite interval. The feasibility of this approach is then demonstrated by numerical simulation of lossless transmission lines affected by soft faults, and by the solution of the inverse scattering problem effectively retrieving smoothly varying characteristic impedance profiles from reflection coefficients.
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/inria-00365991
Contributor : Qinghua Zhang Connect in order to contact the contributor
Submitted on : Wednesday, May 26, 2010 - 5:16:24 PM
Last modification on : Friday, January 21, 2022 - 3:14:03 AM
Long-term archiving on: : Thursday, December 1, 2016 - 3:51:42 AM
File
SoftFaultInverseScattering_TAP...
Identifiers
  • HAL Id : inria-00365991, version 2
Collections
Citation
Qinghua Zhang, Michel Sorine, Mehdi Admane. Inverse Scattering for Soft Fault Diagnosis in Electric Transmission Lines. IEEE Transactions on Antennas and Propagation, Institute of Electrical and Electronics Engineers, 2011, 59 (1), pp.141 - 148. ⟨inria-00365991v2⟩
Share
Metrics
Record views
265
Files downloads
293
